| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#1 | |
Drives: 2013 Scion FRS
BRZ funny Handling
#2 |
The Gunshine State
Drives: '14 BRZ Limited
When was the last time you had an alignment?
![]() Current DD: M235i |
#3 |
#4 |
Drives: 2015 BRZ
Check the tire pressure, check if the wheels are balanced, get an alignment possibly
#5 |
Is everything stock?
#6 |
Bone Stock. (minus carbon gear knob) but Im thinking about those rims that 8RZ posted now. I feel as though it might be relevant to mention the fact that it does have 112k miles one it and I dont know its service history. I was in a minor rear end collision and it was after it was fixed I first started to notice funny handling but it wasnt until I got a nail in my right rear and had both tires replaced that I noticed it in full force. |
#7 | |
#8 | |
I would doubt its the wheel speed sensors because this was a very minor collision (happened in a parking lot backing out of a space and didnt even require any replacement of body panels (The entire parts list to fix it was just touch up paint a bumper retainer and a tail light, Although some body panels did need reworking just not replacing) |
#9 | |
The Gunshine State
But at least a shop would be able to tell if there's something else bent or broken suspension-wise if they can't get it back in spec.
#10 |
This is very true. The point of this post was to get a list of things to have them check out so I dont have to keep going back when one thing doesnt fix it or they cant find anything wrong.
#11 |
Drives: '12 C63 P31, '23 GRC
These cars can be very sensitive to tire pressure, though that doesn't have anything to do with you spinning tires.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#12 |
Drives: STI
If the rear shocks are completely blown it can cause the car to misbehave when cornering on bumps.
You NEED to have your alignment and suspension checked immediately. I mean if your car suddenly feels like it wants to spin out after being repaired from a collision. ugh? Usually I try to refrain from being rude but come on man. I would first get rid of the 2 different types of tires, it's a terrible idea. I rather run stock than do that. Next have car aligned and have a subaru shop check the suspension. I'd also look into those replacement suspension bolts subaru had for 2013's. Next be sure someone checks the axle to be sure its retainer bolt is not messed up (dunno what its actually called). Also they will presumably check shocks/struts |
#13 | |
So luckily this is being done now. It handled ok after the collision repair it was funny for a day then normal. The real issues started when I got the flat fixed a few days ago but hopefully it just needed new tires and alignment which they confirmed was off quite a bit. |
#14 | ||
Wait a second. Did I misread when you said you got new tires? Did you put different tires on the front and rear? If so that can cause all sorts of weird stuff.
| Tags |
| handling, tires, traction loss |
| Found this Funny! | Krazy | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 07-27-2015 08:30 PM |
| Funny | aaguilar3 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 12-12-2014 04:42 PM |
| FRS started funny | N1rve | Issues | Warranty | Recalls / TSB | 23 | 06-04-2014 03:10 PM |
| Funny Pic | whitefrs | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 10-25-2012 10:32 PM |
| funny story | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 09-05-2012 09:27 AM |
