Old 07-15-2019, 01:34 PM   #15
Kcc-Breeze
Drives: 2019 BRZ RS
Originally Posted by Tristor View Post
No, I have pillow ball upper mounts in the rear, as do you. The coilovers you listed in your OP are camber plated in the front and have pillow ball rears. I have a similar setup. You would want to use the corrosion X to fluid film anywhere that you'd expect forces to occur that might cause metal/metal rubbing, such as around the bearing surfaces in the upper mounts, the bolts on the bottom mounts, etc, as well as any of the bearing surfaces on your front and rear suspension links. I replaced most of my rear suspension entirely so now everything is solid/pillow ball, no rubber bushings, and consequently I found that fluid filming all these surfaces made a significant difference in NVH.
The noise doesn't mean anything though, really. Only thing to really worry about is thumping or clunking noises.
OMG the last sentence save my world lol. I was worry I didint install them correctly Cus I was in a rush to do them but I’ll check them again and retorque everything later on.
What is NVH?
You have a set of the hks hipermax Iv sp too?
Are these rebuildable ? You said you replaced the rear?
Just curious like how far or how much Km/miles do one rebuild the coilover
Kcc-Breeze is offline   Reply With Quote
Old 07-15-2019, 01:44 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
NVH stands for noise-vibration-harshness.
As for what mileage - really depends where and how one drives. As in general though, usually i've seen longest mileage out of OE shocks, and less from aftermarket ones, but it might as well be for OE having looser tolerances to begin with, and little change over time, but aftermarket vendors considering less change as big enough to warrant rebuild to still perform top.
There is also bit that shocks often just slowly wear / start working worse at slow enough rates for owner to not notice/getting used to, instead of failing completely or degrading in noticeable step, and often owner may notice only when having drive in car with same but new shocks.
Some have got 100+K miles out of shocks, some change after 10-20K miles. Too roads and driving style dependent to generalize mileage shocks should last.
Old 07-15-2019, 02:57 PM   #17
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
What is NVH?
I don't have the same coilovers as you, I have a similar setup though. I have RCE Tarmac 2s with Vorshlag front camber plates and rear solid mounts. But the HKS Hipermax IV SP has rear solid mounts and front camber plates already. This is what I meant by "we have a similar setup".
I replaced all of my rear links (lower control arm, trailing arm, toe arms) with billet parts from SPL, so they are all pillow balls now, no rubber bushings. For anything with a pillow ball you will get increased NVH, no matter what, it's just the sacrifice you make for better performance. But doing a coating of fluid film on bearing surfaces will help it be quieter.
NVH = Noise, Vibration, and Harshness.
Tristor is offline   Reply With Quote
Old 07-15-2019, 03:14 PM   #18
ls1ac
ls1ac's Avatar
As a test spray the whole darn thing with WD if the squeak goes away you know you are in the right area. then wash off and start over one area at a time.
Old 07-15-2019, 04:13 PM   #19
Kcc-Breeze
Drives: 2019 BRZ RS
thanks for the help I’ll do that rn. Thanks for all the knowledge and wisdoms really appreciated !!
help a suspension noob with coilovers and support Breadman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-02-2018 03:18 PM
OFT - Noob Question jRuN Software Tuning 4 08-21-2018 07:55 AM
Bc Racing coilovers squeak Gus323 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-15-2017 04:30 PM
Noob question about OFT nyfries Software Tuning 4 12-09-2014 12:07 AM
Noob question dro Scion FR-S / Toyota 86 GT86 General Forum 60 07-05-2013 09:33 AM
