Old 09-21-2018, 12:37 PM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
help a suspension noob with coilovers and support
So i know near nothing about suspension but my next mod is coilovers i believe. I just upgraded to 17x9 255/40/17 wheels and want just that little bit of clearance more. currently im running a 3mm spacer in the front but they arent stx legal. i dont really want to lower it much if at all since i already scrape on my friends driveway and PA roads are shit. I assume tein csg spec would be "good enough" because im a mediocre driver and the only thing else id need is a rear lower control arm? If there is anything i missed just chime in, im trying to make my budget for whatever i need now.
Breadman is offline   Reply With Quote
Old 09-21-2018, 12:48 PM   #2
re-animator
if you don't know anything about suspensions and want to maintain stock height why do you want a set of coilovers?
re-animator is offline   Reply With Quote
Old 09-21-2018, 01:05 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
For how he wrote "I just upgraded to 17x9 255/40/17 wheels and want just that little bit of clearance more" - for better too wide wheels clearance.
As for not-lowering .. IIRC flex Z & flex A were a bit lower then stock though even at minimum height drop.
Old 09-21-2018, 01:37 PM   #4
strat61caster
strat61caster's Avatar
CSG Spec Teins will be decent for autox, spring rates are in the ballpark for stiffness (but you'll be sacrificing comfort vs a softer coilover), camber plates will be necessary for using those big tires you paid a few hundred bucks for (I'd suggest -3.5 front camber as a starting point if you're serious about putting up good numbers for autox) and yes you'll need a lower control arm to get the rear camber adjusted, get the cheap SPC arm, no reason to spend more money, some of the fastest cars are using it (-2.5 degrees to start imho). Zero toe front, some toe in rear to taste.
There's a bunch of other advice to spout, but talk to your local STX drivers, ask questions, most autoxers are helpful. There's also tons of information to read up on if you're patient enough to search for it. It sounds like stock suspension likely fits your needs better but what the hell dive on in, it's a hobby.
Oh and nothing is illegal about your wheel and spacer setup for STX. There are alternative coilovers if you're willing to up the budget, but for ~$1.4k I don't think you'll find anything significantly better.
ineedyourdiddly
Breadman (09-21-2018)
Old 09-21-2018, 04:17 PM   #5
2Wavy
Drives: 2016 BRZ
If it were me I'd switch to narrower tires like a 245 for more clearance and leave the stock suspension. That's the tire width I'm on now and I plan on getting coilovers to lower the car soon, but if you don't want to lower the car I don't see the point of getting coilovers. What's the offset on your wheels?
2Wavy is offline   Reply With Quote
Old 09-21-2018, 08:15 PM   #6
Breadman
Breadman's Avatar
i literally said in the post. "currently im running a 3mm spacer in the front but they arent stx legal."
Old 09-21-2018, 08:33 PM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
There is literally an entire sticky thread for this.
http://www.ft86club.com/forums/showthread.php?t=25779
On top of that, like strat said, ask the locals.
Old 09-22-2018, 07:40 AM   #8
scirocco78
Drives: Scion FRS
Wheel spacers are STX legal. There is no rule about offset.
scirocco78 is offline   Reply With Quote
Old 09-22-2018, 09:53 AM   #9
Breadman
Breadman's Avatar
i swear someone told me that spacers that change the suspension geometry were illegal. either way if i wanted to add camber i would need this
Old 10-01-2018, 06:13 PM   #10
Doji Style
Drives: 2014 SWP BRZ
https://dk1xgl0d43mu1.cloudfront.net...pdf?1445897937
Note item 14.4
Any wheel can be used as long as the width is not greater than 9". We've all been here, don't sweat it.
2014 SWP Subaru BRZ
2014 VW GTI
2013 Asphalt FR-S - Sold
Doji Style is offline   Reply With Quote
Old 10-01-2018, 07:23 PM   #11
Breadman
Breadman's Avatar
Note item 14.4
14.8 A
" This does not allow the use of spacers that alter suspension geometry, such as those between
the hub carrier and lower suspension arm."
wouldnt hub spacers be considered this, or is it because they arent in the actual suspension, they dont count?
Old 10-01-2018, 07:53 PM   #12
Doji Style
14.8 A
I'm not sure tbh. My original intentions of sharing this link were not to prove that he could, but more put the rules in front of him. I'm in the process of building an STX car, I've always run in DS so I'm the last person that should answer your specific question.
2014 SWP Subaru BRZ
2014 VW GTI
Old 10-01-2018, 09:09 PM   #13
strat61caster
14.8 A
No.
You are concerned about what is between the hub and wheel. That is explicitly allowed in Street rules, section 13.4 which carry over into street touring without the restriction of +/- 7mm from factory per the 14.4 rule mentioned above.
The rule you're referencing is to prevent spacers that change suspension geometry such as this which acts as a spacer between the hub carrier and suspension arm:
Other suspension designs make it easier to add a spacer and change suspension geometry than the 86, but this is what that rule is getting at.
ineedyourdiddly
Old 10-02-2018, 03:18 PM   #14
wparsons
wparsons's Avatar
That spacer would be an extended ball joint, or something else to change the roll center.
Just a quick point, the SPC LCA's are technically not STX legal (they have a bearing instead of bushing), IIRC the whitelines are totally fine though, as well as the racer X and verus ones labelled as STX legal.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
cjd (10-02-2018)
FS: ST Suspension Coilovers stevohl Brakes, Suspension, Chassis 11 04-07-2015 03:37 PM
noob to suspension info? lbroskee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-16-2014 04:05 AM
Noob asking about wheels and suspension Arsenio3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-13-2014 11:06 AM
Suspension noob thinking of getting Eibach Pro-Kit Lowering Springs teamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 12-28-2013 02:01 AM
