Old 08-20-2018, 03:18 PM   #1
jRuN
OFT - Noob Question
So i just grabbed my OFT (v1) from another member. I went on OFT's website and downloaded all of the tunes for my calibration.
Files looked like this:
Stg-1-v4.03-LC-FSS-ZA1JD00c.bin
Stg-2-v4.03-LC-FSS-ZA1JD00c.bin
Stg-2-Plus-v4.03-LC-FSS-ZA1JD00c.bin
Stg-2-Plus-E85-v4.03-LC-FSS-ZA1JD00c.bin
Questions!
1. None of these tune files mention what fuel grade they are for? Are they all assuming 91 octane?
2. I am in FL and use 93 octane. I went and download the "Master List" of tune files and found sub-folders that indicated:
Stage 1 - 91oct
Stage 1 - 93oct
etc etc..
Is the tune file in the 93 octane folder the one that i would use then with the 93 octane gas i put in? These tune files don't list a version number like the v4.03 tune files.. are they older?
I noticed on the v4.03 tunes the IAM was .70 and the IAM on the 93octane tune is 1.00. So i just wasn't sure if these 93 octane tunes were older and not updated.
Thanks for your help!!
John
jRuN is offline   Reply With Quote
Old 08-20-2018, 03:47 PM   #2
tomm.brz
Drives: brz 2017 hksv2
v4 are universal, they start with 0.7 iam and if you put 93 oct it should raise to 1 after few pulls
Old 08-20-2018, 04:45 PM   #3
Scala
Drives: 2018 BRZ tS
Have you reached out to OFT?
Scala is offline   Reply With Quote
Old 08-20-2018, 05:38 PM   #4
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Questions!
Stage 1 - 91oct
Stage 1 - 93oct
etc etc..
John
The 91 and 93 are indicative of the fuel type. If you have 93 in your area, then use the folder that has 93 on it. That is precisely what is is referring to.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 08-21-2018, 07:55 AM   #5
jRuN
This is the correct answer. OFT responded to me and said i should be using the v4 tunes and they will adjust to the higher octane rating that i am using.
They are designed with 91 octane fuel from CA.
The 93 octane tunes i found from the master list are older tunes.
Hope this info helps any other noobs!
And thank you Tomm.brz as well!
Noob question about OFT nyfries Software Tuning 4 12-09-2014 12:07 AM
noob question here about f.I.... zimzum Forced Induction 7 03-06-2014 04:24 AM
Noob question dro Scion FR-S / Toyota 86 GT86 General Forum 60 07-05-2013 09:33 AM
noob question ft86me Engine, Exhaust, Transmission 13 02-28-2013 04:53 AM
