Old 07-15-2019, 12:28 PM   #15
strat61caster
strat61caster's Avatar
Originally Posted by ermax View Post
I’m not saying it isn’t possible to reach the bumps but to say the spring rate changes with bumps stops is just nonsense.
https://www.ft86club.com/forums/showthread.php?t=26661
There's about a half inch of suspension travel before you engage the bumpstops and with <200# springs that half inch disappears pretty damn quick.
ineedyourdiddly
Old 07-15-2019, 12:30 PM   #16
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I don't see any real advantage to cutting the bump stop. The suspension is designed around using it in most cornering. It's a progressive spring system, and a pretty good one at that.
The Following User Says Thank You to EAGLE5 For This Useful Post:
strat61caster (07-15-2019)
Old 07-15-2019, 12:38 PM   #17
Racecomp Engineering
It's designed to corner on the bumpstops. They have their own spring rate and progression.
Depending on how you cut the bumpstops (such as cutting from the softer or stiffer end), you change the overall spring/bumper system in different ways. But they're designed as a complete unit.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
RedReplicant (06-25-2022), strat61caster (07-15-2019), wparsons (07-15-2019)
Old 07-15-2019, 03:54 PM   #18
ermax
ermax's Avatar
- Andrew
Interesting. I’ve done bad spring selections on other cars and ended up riding the bumps and it was obvious and handled like trash. I didn’t realize the Twins road the stops by design. My Integra was twitchy and unpredictable on the stops. Then again the stops on that car were rock hard compared to the ones on the FRS. If I didn’t have the dust covers on I’d throw some zip ties on to see how far they climb just out of curiosity.
Old 07-15-2019, 04:12 PM   #19
It's a trend over the last 20 years for cars to use be more bumpstop active, and so the initial progressions of the bumpers are relatively soft and it's difficult to feel when you start getting into them. That's also why cutting just the soft part of the bumpers may not provide the effect people want.
I have a theory as to why manufacturers are doing this but just a theory.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
FS: 2017 Springs/Bump Stops Drambeenie Brakes, Suspension, Chassis 4 06-10-2018 02:42 PM
Different bump stops came with my RCE Yellow springs kuangxtc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-19-2016 08:07 PM
SWIFT Spec R Springs - Bump stops project d Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-03-2014 08:25 PM
Lowering springs and bump stops survey solidONE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-27-2013 11:23 PM
Swift Springs: Cut OEM Bump Stops? BillY2KFRC Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-22-2013 01:45 PM
