Old 07-10-2019, 12:34 PM   #15
maslin
Benz Tech
Drives: 2017 BRZ Premium
Originally Posted by BEZO760 View Post
Thanks for the advise man! I think ima lower it another half inch and see how that goes for a month or so. One more thing. I know an alignment is needed when coilovers are switched out, I got one, but lowering it 1\2 inch won't require an alignment right? Since the coilovers are already on
Yes, it will. Changing ride height changes toe, you will absolutely need an alignment.
maslin is offline   Reply With Quote
The Following 3 Users Say Thank You to maslin For This Useful Post:
BEZO760 (07-10-2019), timurrrr (07-11-2019), Tristor (07-10-2019)
Old 07-10-2019, 02:44 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
+1 to what maslin said. There are some suspension designs that have their settings more independent/less intertwined, eg. multilink/double wishbone ones, but often geometry even of those is designed in way, that changing one thing changes other to some extent. As handling feel depends a lot from alignment, better not try to save on not doing it.
The Following 3 Users Say Thank You to churchx For This Useful Post:
BEZO760 (07-10-2019), maslin (07-10-2019), timurrrr (07-11-2019)
Old 07-10-2019, 03:36 PM   #17
BEZO760
Drives: Blue 2016 SCION FR-S
I got a deal with my local tire shop for a lifetime alignment knowing I would be messing with the suspension quite often. I just wanted to make sure one was indeed needed before I show up and get my second alignment this week.
BEZO760 is offline   Reply With Quote
The Following 2 Users Say Thank You to BEZO760 For This Useful Post:
maslin (07-10-2019), NoHaveMSG (07-11-2019)
Old 07-11-2019, 01:35 AM   #18
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You might also consider corner balancing
timurrrr is offline   Reply With Quote
Old 07-11-2019, 01:49 AM   #19
BEZO760
I was always under the impression that corner balancing was an OP move for regular vehicles. I don't hear of many people doing it. Would you care to explain a bit more? I'll probably research it in the morning nonetheless. Good food for thought.
Old 07-11-2019, 10:37 AM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Corner balancing is over kill. Even for the occasional track day. Until you are comforatable and good at sensing little changes in suspension adjustment/settings. I wouldn't bother.
Last time my car was aligned was in the parking lot, at the track
The Following User Says Thank You to NoHaveMSG For This Useful Post:
maslin (07-11-2019)
Slight front wheel bounce on sharp right turn? iceblaze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-09-2018 12:43 PM
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 04:25 PM
Slight buzz at 1,500 RPM ericmpena Engine, Exhaust, Transmission 5 05-02-2014 08:35 AM
How to tell if front wheel is rubbing against strut? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-08-2013 09:54 AM
LIST: Non-rubbing 17" wheel & tyre packages ft_sjo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-28-2013 06:56 AM
