Old 06-25-2019, 10:59 AM   #15
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Originally Posted by wparsons View Post
Get out a voltmeter and actually measure the voltage at the TPS (on the throttle body). If the code is saying it's below the minimum voltage, and gives you the expected minimum voltage, that's a very good place to start.
If you're going to go with the logging route, log both the throttle position and pedal position and give the throttle some obvious inputs, look for it to be logged and see what the TPS is showing at the same time.
Thanks for your continued help. I borrowed a meter to use but I've never actually used one. I found the wiring diagram (http://www.ft86club.com/files/BRZwiringi.pdf) how do I test this? If I just displayed gross incompetence and you think I should leave it to a mechanic say so, I won't be offended lol.
Kerber23 is offline   Reply With Quote
The Following User Says Thank You to Kerber23 For This Useful Post:
wparsons (06-25-2019)
Old 06-25-2019, 11:02 AM   #16
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
TPS (throttle position sensor) is in the throttle body, even on drive by cable cars. The pedal sensor tells the ECU how much throttle you want, the TPS tells the ECU how open the TB actually is.
Argh! My bad. I meant pedal position.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 06-25-2019, 11:05 AM   #17
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Haha its fine. Ill go take a look!
Old 06-25-2019, 11:12 AM   #18
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
https://gyazo.com/c74d62a87990904eb87bdada0c74d74c
Edit: sorry saw the other post
is this what you were looking for in the log?
Pink is Accelerator angle
Blue is throttle angle
I most certainly floored the accelerator and tapped it several times when the Accelerator angle read 0 but the throttle angle plateued.
Old 06-25-2019, 11:56 AM   #19
wparsons
wparsons's Avatar
Hold up, you floored it in that log? The max pedal angle I see is like 35%.
flickr
Old 06-25-2019, 02:00 PM   #20
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
I floored it when the Throttle Angle was more elevated dispite accelerator angle showing 0. I floored it. Tapped it. And it showed 0 change in throttle angle
Old 06-25-2019, 02:25 PM   #21
wparsons
wparsons's Avatar
Can you get a log with the car not running and just sweep the throttle pedal angle from 0 to WOT and back slowly? I don't know if it'll move the TB with the car off not running, but it'll be interesting to see what the pedal is logging.
flickr
Old 06-25-2019, 04:51 PM   #22
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Part of the issue you are having is the subaru limp mode. It maxes rpm's at 4k when any lights go on. My guess is that is why it only goes to 4k, and not revs the engine until it explodes.
There's always a chance the tuner broke the map in some way the car wasn't expecting with the throttle position.
Old 06-25-2019, 04:58 PM   #23
wparsons
wparsons's Avatar
Unless I misread it, he said it hangs at 4k rpm even without throttle input. Limp mode would stop it from revving higher, but shouldn't hold it there without touching the gas.
flickr
Old 06-26-2019, 07:09 AM   #24
why?
why?'s Avatar
Drives: series.blue
Unless the sensor was broken. I had a car do this to me decades ago, there was a piece that stopped the throttle from going farther down and it broke. When I didn't press the pedal the car always revved to 2000 rpm. I assume subaru doesn't use that piece for drive by wire, but I can easily see if the sensor is broken ( or the map values are messed up) it decides it should rev at 2k rpm's.
Old 06-26-2019, 04:31 PM   #25
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Would it also ignore all throttle input when that happens? I'm asking the local group if I can borrow someone's gas pedal since it seems its all one unit.
Old 06-26-2019, 05:08 PM   #26
Kodename47
Kodename47's Avatar
Drives: UK GT86
Tried this? The throttle will move with the pedal if all is well and is logable.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
wparsons (06-27-2019)
Old 06-26-2019, 05:49 PM   #27
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
I was able to log the both with the car in the accessory position. The accel went from o-100 and I heard the throttle body opening as wel.
Old 06-26-2019, 10:53 PM   #28
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
As stupid as it seems wipe the codes and battery reset the ecu. That should fix your 4k issue. And likly what your seeing with the tps. I'd start with the map. Sadly, when I had issues with mine, LJ could only sell me another one to see if that fixed the issue. Fbm map sensors are just restickered omni 3/4 bar sensors should you noy want to spend 90$.
Subaru Dealer Holds BRZ Hostage After Facebook-Stalking The Owner's Track Day Photos Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 35 08-19-2017 12:46 AM
Where do you keep your revs? ScionFrsFan Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2015 12:07 AM
Caliper Sliding Pin - What Holds It In? elbles Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-08-2014 09:03 PM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
BRZ holds its own in Auto-X with rookie driver mtimney Tracking / Autocross / HPDE / Drifting 4 08-11-2013 12:24 PM
