Old 06-08-2014, 06:31 PM   #1
elbles
Drives: 2013 Subaru BRZ
Caliper Sliding Pin - What Holds It In?
Hi all,
I just did pads, rotors, and fluid yesterday, and 3 of the 4 wheels came out fine. The passenger front is sticking though, and generating quite a bit more heat than the others. It's not enough to notice it pulling, but the temperature was nearing 400 degrees F after a test run, after fixing what I thought was the problem (in one of the sliding pins).
After letting it cool down, and taking it apart again, I can't get the sliding pin to "spring" the way the top one does (the problematic one is the one closest to the ground).
In looking in the caliper carrier, I don't see any threading to match up with the threads embedded in the rubber portion of the sliding pin.
Any thoughts on what I'm doing wrong, or where I can get parts to get it working properly at nearly 7 PM on a Sunday?
elbles is offline   Reply With Quote
Old 06-08-2014, 06:38 PM   #2
wparsons
wparsons's Avatar
I might be picturing it wrong, but isn't the threaded part in the caliper itself? IIRC the bolt runs from the back of the caliper carrier through the slider into the caliper?
flickr
Old 06-08-2014, 07:02 PM   #3
elbles
Yeah, the part that I'm having a problem with is the sliding pin in the caliper carrier itself--the top sliding pin goes down all the way, and when you give it a tug, it springs back down to the bottom of the caliper carrier.
The bottom one doesn't do that--I can push it in all the way to the bottom, but if I tug it the same way, it just pulls out. Nothing "pulls" it back to the bottom of the caliper carrier.
I'm probably explaining it poorly, but nothing I've done has got it working that way again, and I don't think I want to drive the car in this condition.
Thanks for the reply though.
Old 06-08-2014, 08:27 PM   #4
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Just the rubber dust boots, if I'm thinking of the right part.
celica73 is offline   Reply With Quote
Old 06-08-2014, 08:41 PM   #5
juliog
juliog's Avatar
Drives: 86
Replace the rubber dust boots and apply brake / high temperature grease. You can find both at your local pep boys..
juliog is offline   Reply With Quote
Old 06-08-2014, 09:03 PM   #6
elbles
Thanks guys. I had inadvertently pulled out one of the sliding pins on this wheel while putting the caliper back on, and while I had greased it back up, and even though it still felt "stiffer" than the other one, the other one held a vacuum or something.
Redoing *that* sliding pin got that rotor to within 10 degrees of the other one, rather than being over double the temperature.
Please excuse the not-so-mechanically-inclined. :-)
Me sliding on the street... wilfredwong Northern California 31 03-27-2014 06:11 AM
sliding around in the snow, burning smell... amram Scion FR-S / Toyota 86 GT86 General Forum 12 02-13-2014 08:36 PM
BRZ holds its own in Auto-X with rookie driver mtimney Tracking / Autocross / HPDE / Drifting 4 08-11-2013 12:24 PM
Sliding my FR-S in the rain? Texas BRZ Southwest 23 10-01-2012 11:10 AM
Passenger seat not sliding to let people out.. wparsons Issues | Warranty | Recalls / TSB 9 10-01-2012 07:28 AM
