#15 | |
Drives: 2019 Toyota 86
Gonna be real honest here guys. I like how CAIs look in the engine bay and I like the noise and I'm aware that the most HP I'm gonna get is +2 or +3HP. Except I'll probably go Grimmspeed instead if it can clear my oil cooler.
#16 |
Drives: 2014 GT86
Ryan GT86: btw, stock intake also is CAI. But if you must buy aftermarket intake, then good choice on Grimmspeed's, as it is one of few, that doesn't mess with much with MAF sensor readings to artificially lean AF, and also doesn't require removal of bumper for filter change
| The Following User Says Thank You to churchx For This Useful Post: | wparsons (04-04-2019) |
#17 | |
#18 |
Drives: 2014 GT86
If using Perrin's, then i guess MAF sensor will need recalibration in ECU tune. In your place i'd keep using stock intake/airbox, and install aftermarket drop-in airfilter. Most of gains, for minimal cost, less to loose when reverting to stock prior sale.
#19 |
The version I'm planning on is the CARB certified CAI that doesn't need a tune. The version that needs a tune is discontinued according to FT86SF.
#20 |
Drives: 2017 BRZ
The ECU compensates well enough... But the result is power loss.
#21 |
Drives: 2014 GT86
As cjd wrote. One thing is CARB certification, which is about emissions and maybe legality in some states, another - about actual gains (and in some cases - safety). For later, aftermarket part should behave similar to stock in areas other parts depend on, or have differences taken into account in other parts (i.e. - in ecu tune). Which often negates "gains".
In many cases "gains" with aftermarket intakes by large portion were artificial in way of fooling MAF sensor readings, resulting in engine running leaner when regulated by stock ecu tune from those readings. Leaner, thus with more power, but more prone to knock, especially with worse fuel. Hence better consider using intakes, that don't sink to such means for artificial gains, and whose MAF readings won't differ much from stock intake. Usually i seen mentioned as such two of them - TRD's & Grimmspeed's. My own choice would be drop-in airfilter, but if going for full intake, i'd choose from those two. |
#22 |
Drives: car
I don't think the CAI is in too low of a location for water damage.
Those telling him not to get a CAI probably haven't been in a tuned 86 with a Perrin CAI. They sound great. |
#23 | |
Drives: 2014 Subaru BRZ
I recently installed a Perrin CAI simply because it sounds rad!! gives higer rpm range a throaty sound. |
| Disable high Rev cold start | Raven604 | Engine, Exhaust, Transmission | 408 | 03-28-2022 11:27 AM |
| Perrin Cold Air intake CAI (black) and AVO silicone intake tube (blue) | Joesurf79 | Engine, Exhaust, Bolt-Ons | 13 | 07-29-2016 03:38 PM |
| Need help disabling high rev cold start with OFT | MikeM7 | Software Tuning | 5 | 09-14-2015 05:12 PM |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 01:43 AM |
| TRD CAI and Hydrolocking | Taro | CANADA | 3 | 09-27-2013 01:02 AM |
