| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Haha they make it look and sound so simple
https://demos.starbase7.net/t3Portal..._rm_index.html https://demos.starbase7.net/t3Portal..._rm_index.html |
| The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (03-27-2019) |
#16 |
Do you want me to send Bubba's son over to get that off for you?
![]() humfrz |
#18 | |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jcw99 (03-28-2019) |
#19 |
After 5 of them...
| The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (03-28-2019) |
#20 |
So, are you making progress?
humfrz |
#21 |
Done! Another couple of hours of pounding with big hammers and cold chisels behind the backing plate got 'er done. I had a mobile mechanic come by to teach me how to remove (and reassemble) the parking brake and he brought a bfh and large chisel. We got the whole assembly off then took it to the bench and beat the bearing carrier out of the plate.
https://imgur.com/a/W8EwEvB The surprising thing was the rust that was holding it in is the only rust in that area of the car. The entire assembly is clean and dry, other than some surface corrosion the suspension bits are in great shape. I do need a bit of touch up paint for the wide swings with the hammer around the wheel well though
#22 | |
humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | gravitylover (03-29-2019), jcw99 (03-30-2019) |
#23 |
not playing cards
clip on the rear shoe is upside down. -5
#24 |
Haha yeah. I'm going to pull the rotors off soon and get them turned anyway. They look like shit and don't have many miles on them since I changed the pads and rotors. I think I got some crap stuck on the passenger side and have a sticky piston on the drivers side. A little tlc is in order. When I pull that side I'll flip that clip over just because it bothers you
#25 | |
not playing cards
![]() edit: As long as we're on the subject, I used to get rotors turned too. These days, I suggest installing fresh ones. They aren't much more expensive, and maximum width of the rotor means minimum extension of the pots. It's probably trivial benefit but I feel good about it.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
| Problem with car around 4K rpm | Scion1738 | Issues | Warranty | Recalls / TSB | 13 | 11-27-2015 11:59 PM |
| Problem with OFT | Harry04 | Software Tuning | 3 | 06-18-2015 07:35 PM |
| DRL problem | benlaz88 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 09-19-2013 08:58 PM |
| Has anyone have this problem....... | CSI:86 | Issues | Warranty | Recalls / TSB | 29 | 06-17-2013 09:29 AM |
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 07:07 PM |
