Old 04-24-2019, 02:27 PM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by Sgaldi View Post
Ok so I guess I got the new one cause mines red, iv been reading around and trying to figure out what would be best for the BRZ engine as far a durability and life if the engine , a supercharger or a turbo, from what iv read you don’t want to go above 7psi cause the engine can’t take it...so I was thinking somthing around 5psi for longevity, and info ? I’m not very auto savvy
If you are after the safest F.I setup, go with a centrifugal S/C like jackson racing's kit. The way they build boost with RPM is less stressful on the bottom end, the rods specifically which are known to snap when you up the torque.
Turbo kits and twin screw setups will make a lot more torque down low which will put more strain on those components. The trade off is that they feel faster through the entire rev range, as apposed to centrifugal blowers retaining the factory powerband, just more of it.
Old 04-24-2019, 03:45 PM   #16
Originally Posted by RToyo86 View Post
You've got to pay to play. Don't add boost if you can't afford to rebuild if it blows up tomorrow.
This should be included on any and all performance parts instructions!
86MLR (04-24-2019)
Old 04-24-2019, 04:01 PM   #17
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Not quite all the same. They all have some of the upgrades. Not having the red intake doesn't mean it is the "old" engine it just means you didn't get that whopping extra 5HP. There are still many improvements even without the HP gain so it is worth being clear.
my bad then had no idea the remaining markets that didn't get the power bump also received some updated internals.
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
Tcoat (04-24-2019)
Old 04-24-2019, 04:12 PM   #18
Yep. They got every single upgrade on the car except the intake, exhaust and final. The engines look like the old ones since they still have all the old externals but everything else is changed. There was a lot more changed than people seem to think through the whole car.
HKz (04-24-2019), why? (04-26-2019)
Old 04-24-2019, 05:09 PM   #19
Sasquachulator
Pavement Grey
no power number change = no changes!!! car is the same as in 2012!!!!
because NOT RACECAR!
Old 04-24-2019, 08:39 PM   #20
86MLR
86MLR's Avatar
I've seen worse mid life crisis upgrades that only revolve around exterior and interior changes.
The 17+ upgrades were at least focused on some of the known issues.
Not everything is about power.
If you want more power you could always spend a bit more money, or, not shop in the basement for the cheapest RWD sports car on the planet and complain about powaaaahhhhs.
Have you seen this PDF?
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 04-24-2019, 08:46 PM   #21
Pretty sure he was being sarcastic.
Old 04-24-2019, 08:55 PM   #22
HKz
Reformed
HKz's Avatar
weirdo o.O
Old 04-24-2019, 08:59 PM   #23
86MLR
86MLR's Avatar
Opps, sometimes I'm just like my 86, slow.......but I can change direction really well..
STOP JUDGING ME.........
In other news I'm getting a alarm (all the bells and whistles) installed so the car beeps when I lock it.
$500 for beeping noises, sometimes I think I've taken way to many hits to the head.
The Following User Says Thank You to 86MLR For This Useful Post:
Tcoat (04-24-2019)
Differences between auto and manual engine redlined600 Engine, Exhaust, Transmission 38 06-21-2023 11:35 PM
Brand New 2018 BRZ - Check Engine Light at 85 Miles Clutch Issues | Warranty | Recalls / TSB 40 02-25-2019 02:40 PM
Best Turbo kit for stock engine? As of 2018... Conman Forced Induction 21 01-02-2019 09:17 AM
Engine from Auto car into a manual car? John Rambo Engine, Exhaust, Transmission 8 11-26-2015 04:54 PM
