Old 07-10-2020, 03:06 PM   #15
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by DarkPira7e View Post
What clutch are you guys using? Excited to see how long your gears last at this torque.
This is an ACT HD pressure plate with a 6 puck sprung clutch left over from an old build. We don't plan on beating on it at 500 hp, stock axles, trans, and diff will be very short lived at those HP levels and sticky tires. We're going to mostly run it in the 300's, which is hard enough already for the stock stuff. We may go the cd009 route if needed, but right now we'll see how we do at the 300's.
One thing I did fail to note in the prior post is that this is all with a 2.5" exhaust. We specifically ordered that way to keep costs, weight, and noise down. Aside from a couple hundred RPM of loss of spool, the smaller pipes made no issue getting to 500.
Xero-Limit is offline   Reply With Quote
Old 07-10-2020, 04:41 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Awesome, that makes sense. Yeah I'm worried about what will give out first on my car. I'm leaving stock axles in the car to hope they give before gears do. I'm planning on about 300wtq. With a smaller turbo and stock exhaust I was making 250wtq before, I don't think many people realize that the larger piping just makes thing easier, not impossible.
Old 07-10-2020, 06:33 PM   #17
solidsnake11
Drives: brz
Awesome!
solidsnake11 is offline   Reply With Quote
Flex's Reliable Turbocharged DD/Occasional Track Build FirestormFlex Member's Car Journals 3 03-23-2016 07:00 AM
Realistic cost of engine build for reliable 400whp MyNameIsCacauate Forced Induction 4 01-09-2016 11:33 PM
Affordable Mods S84kam Cosmetic Modification (Interior/Exterior/Lighting) 13 06-30-2015 02:39 AM
17x8.5, affordable? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 06-05-2014 11:56 PM
Affordable vacuum? swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 04-02-2014 06:21 PM
