Old 06-04-2014, 08:00 AM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
17x8.5, affordable?
Any 17x8.5 with a not hellaflush/trackable offset that I can buy for less than ~$350 a wheel?
I don't need some JDM as fuk yo $800 a wheel
I'm looking for a wheel I can run 225 tires on and in the future run 245 if necessary
If I can't find a decent 17x8.5 I will just buy some Kosei 17x8 +36 wheels for 200 a pop
Old 06-04-2014, 08:18 AM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Desmond Regamaster 17x8 - Can find those for about $1-1200 for a set.
Enkei RPF1 - $1200ish?
slicktop is offline   Reply With Quote
Old 06-04-2014, 08:50 AM   #3
DarkSunrise
DarkSunrise's Avatar
Enkei RPF1 is probably your best bet.
The choices for light, affordable 17x8.5 wheels are severely lacking.
2022 BRZ Build
2013 FR-S Build
Old 06-04-2014, 09:09 AM   #4
stevemp5
Drives: scion fr-s
Phatfux wheel! Model balzy. I paid 250 per wheel! http://www.phatfux.com/wheel.php
stevemp5 is offline   Reply With Quote
Old 06-04-2014, 09:23 AM   #5
acg2010
Drives: 4 wheels/engine/seats
xxr 527 17x8.25 +35 at 120ish a wheel.
acg2010 is offline   Reply With Quote
Old 06-04-2014, 09:26 AM   #6
Model Citizen
Lacking brains
Drives: frz
keep an eye on craigslist, it takes time, and being the early bird once a worm pops up but it does work. Applications (whatever is good for your preferred platform) help massively with finding deals, wether it be ones that allow you to search multiple areas at once, or ones that combine that with automatic searching. Craigshopper on osx is either the best or worst $6 a person could ever spend.
last summer got 17x8 rpf1, 0 curbing, decent paint, tires that were easily usable for a few months for $600.
yesterday got a set of rota grids, freshly powder coated, 17x9, with zii tires in great shape. for not much more than the tires would have been on their own.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-04-2014, 10:09 AM   #7
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
720 Form wheels are available in 17x9 and are fairly light for around $200 a wheel if those work for you.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-04-2014, 10:24 AM   #8
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
xxr 527 17x8.25 +35 is what I got for $435 for a set of 4 after shipping. They are about 16-17lbs. Studies have shown it doesn't make you any faster putting lighter wheels on the car. Study was performed by a Miata group. I need to find the link.
stockysnail is offline   Reply With Quote
Old 06-04-2014, 04:55 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
looks like im stuck with XXRs... will see when I actually buy wheels but I doubt anything will change by then
thanks
Old 06-04-2014, 04:58 PM   #10
husker741
There's a dude with 3 cheap BBS wheels that are 17x7.5 on here. I have seen a single one for sale on eBay.
husker741 is offline   Reply With Quote
Old 06-04-2014, 05:04 PM   #11
gramicci101
Off Topic
There's the Sparco Tarmac, 17x8 for $120.
Enkei's Tuning series has a number of 17x8 and 17x9 wheels with decent offsets, but they're all $200 +/- $10.
Old 06-04-2014, 05:12 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
I know there are plenty of 17x8 and 17x9, I want 17x8.5
I'm not planning to ditch stock suspension for some time and I need room to have a little bit of camber.
Old 06-04-2014, 05:21 PM   #13
gramicci101
Off Topic
I'm not finding very much in 17x8.5 without dropping a ton of money. Could you go to 18, or would you rather not?
Old 06-04-2014, 08:02 PM   #14
Cards2323
Drives: 2014 BRZ Limited-SWP
If you dont mind buying used SSR comps had a wheel in that size. They seem to be popping up a lot on nasioc for under 1000.
Cards2323 is offline   Reply With Quote
Affordable vacuum? swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 04-02-2014 06:21 PM
An alternate to OEM Audio + that's actually affordable BMHumanic Electronics | Audio | NAV | Infotainment 24 02-28-2014 06:28 PM
Affordable Gt Spoiler for FRS? Kanye Cosmetic Modification (Interior/Exterior/Lighting) 3 09-17-2013 01:11 PM
S7F Wheels Replica affordable NoFear99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-27-2013 08:58 PM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
