Old 03-15-2019, 01:57 AM   #15
Blackedout86
Drives: 2012 Toyota FT-86
Originally Posted by chipmunk View Post
Do you happen to have any insurance OBD plug-in device that monitors driving habits?
I had a Progressive Snapshot that drained the battery overnight. A few years ago Progressive was sued for this drainage.
unfortunately i dont have that
Originally Posted by HappyRobot View Post
Have you tried jump starting the car? I had a battery issue where the accessories worked, but the starter would not engage. The car started when we jump started it and ended up being a faulty battery.
yes i have tried jump start it, but it still won't work.
Originally Posted by guybo View Post
Click click. Battery tested good.
Remove both battery cables and wire brush them. Same with terminals. Try to start again.
If it still doesn't start, have someone tap the starter with a hammer (lightly) as you push the start button. This is probably where the clicking is coming from. Your symptoms sound like a bad starter. If tapping the starter works, don't shut it off and drive to a mechanic
I have checked and cleaned the cables, but still nothing changed. i've heard about tapping the solenoid, but i dont know how it actually looks like, could you show me where is it please ?
Blackedout86 is offline   Reply With Quote
Old 03-15-2019, 02:01 AM   #16
Blackedout86
Check the fuses too. I had the 7.5amp "Stop" fuse blow, and the car wouldn't start.
Also, I just realized I have never changed my fob battery. Same battery from 2012.
EDIT: If a battery is really dead, you may need 2 sets of jumper cables to get the car to start. (especially if you have cheaper ones with small gauge wire)
i will try to check the fuses asap, the battery is good, i even tried borrowing a new battery but its outcome is the same.
Originally Posted by qcbaker View Post
When you had the battery tested, did the mechanic just test the voltage at rest or did they perform a load test? Sometimes batteries can test okay at rest but voltage drops when load is applied. I wouldn't completely rule out the battery being the issue until you have it load tested.
Starter would be my next guess if the battery actually is fine though.
they did a load test too, i just forgot to take note of the numbers but its still normal, almost like a new battery.
Old 03-15-2019, 07:24 AM   #17
The starter failing would not cause all the dash lights to go out. You have a fuse or wiring issue someplace. Did you recently do anything to the car at all? A common issue is people that do work but do not reinstall the ground on the block properly.
Old 09-16-2019, 11:13 PM   #18
entaroadum
Drives: 2013 Subaru BRZ
Hey guys, sorry for reviving old thread. I have exactly the same symptoms. Tried a different (new) battery, jump start and it wont even try to crank.
Car is '13 BRZ Limited, 45k (5k on mew engine). Any ideas?
entaroadum is offline   Reply With Quote
Old 09-16-2019, 11:42 PM   #19
Ultramaroon
not playing cards
Ultramaroon's Avatar
Standard, or auto?
Old 09-17-2019, 12:14 AM   #20
entaroadum
Standard, or auto?
Auto
Old 09-17-2019, 12:24 AM   #21
Ultramaroon
not playing cards
Auto
Well, shit. There goes the clutch switch idea. Do you get any good hard clicks? Light ones?
Old 09-17-2019, 05:13 AM   #22
New engine? Check how tight the ground strap is to the bell housing.
Old 09-17-2019, 09:08 AM   #23
entaroadum
No clicks at all. Just the usual light show and needle dance in the dash
Old 09-17-2019, 11:54 AM   #24
entaroadum
Update: car now at dealership who installed new engine. they "jumped" the starter and the car started right up. They suspect an issue with the key fob and immobilizer system.
The Following User Says Thank You to entaroadum For This Useful Post:
Ultramaroon (09-17-2019)
Old 09-17-2019, 03:18 PM   #25
entaroadum
"Final" Update: they check techstream and found no issues at all. After jumping the starter the car continued to start flawlessly on it's own.
I have changed the battery on the key fob but it seems it was working OK. I hate self-fixing issues as I now fear it will happen again at the most inconvenient time & place
Old 09-17-2019, 03:26 PM   #26
I repeat. Check the ground connection on the flywheel. If it is loose or dirty then their "jumping" the starter may well have made it connect well enough again. The first time it gets wet or jostled you could loose power again. It may be fine but it is a simple check to be sure. Since it get's disconnected for an engine pull we have seen it as an issue with your exact same symptoms on here many times.
Old 09-17-2019, 03:26 PM   #27
chipmunk
Drives: _
Evil technology!
Horse buggies never had key fobs!
Sent from a potato
chipmunk is offline   Reply With Quote
Old 09-17-2019, 03:35 PM   #28
Evil technology!
Sent from a potato
You ever try to get a horse that doesn't want to move going?
Oh and they did have fobs for the stubborn ones.
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 12:55 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
FR-S wont start or click... KingLos Issues | Warranty | Recalls / TSB 3 12-02-2016 01:38 AM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 12:43 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
