Old 11-30-2018, 01:44 PM   #15
fatoni
I just took a chance with the flex z for the price. I've heard good things about then but I have realistic expectations.just need something to replace worn out 2013 suspension and give me time to understand what I want from the car.
Drive upgrades. Don't buy them.
Old 11-30-2018, 01:58 PM   #16
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
At 700, save a little more to avoid rebuying something else down the line
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 11-30-2018, 02:04 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Our stock suspension has coilovers. Springs being more comfortable then some of aftermarket coilovers sounds a bit misleading. Imho it would be better worded that stock shocks in many cases are more comfortable then many aftermarket offerings (due most commonly having softest rates among them).
Though there is problem with limiting bump travel when lowering too much. Both springs for stock & aftermarket coilovers should have much firmer spring rates to not easily bottom out with now too unwisely little travel left. So when lowering that much comfort will be lost with both lowering springs and coilovers. And in addition to that also fscked up geometry. Given that low budget was mentioned, makes me guess that OP won't have budget for extra parts needed, eg. for roll center adjusting, diff riser and so on. Handling and comfort will be compromised in all lowering for cheap 2" ways, so imho he should just do whatever he wants. All ways will suck or will need more money then he wants to spend .
Imho advise #1 should be to be more reasonable with extent of lowering and lower less, within 1".
Old 11-30-2018, 02:25 PM   #18
alphasaur
friendly
Drives: 17' 86
Originally Posted by AutoNewb View Post
You're definitely right. Its a better BANG for the buck if you don't drive in the winter or live in California. They will still rust in the salt and snow. Since the OP lives in Chicago, I wouldn't recommend them unless hes only driving in the summer.
theyre still coated, just not with the inox coating. i had st on myazdaspeed 6 through winters sans issues.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-30-2018, 02:32 PM   #19
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Everybody is going to say whatever coilover they have is the best. I have and would look into the Meister R Zeta coilovers. They are designed for the shitty raods apparently in England. They are very good on the shitty roads over here as well. I paid less than <$800
https://www.meisterr.com/products/zetacrd-plus/
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
BRZyJ (11-30-2018)
Old 11-30-2018, 04:42 PM   #20
86MLR
86MLR's Avatar
My MCA Street Performance coilovers with 6kg front 4.5kg rear with dampening to suit are more compliant than OEM and handle much better than OEM PP Sachs.
Plus the 20mm recommended drop puts the rear camber right on -2.0°.
Front is set to -2.2°.
Apart from the traction mod and RS4's the rest of the suspension is stock.
Brilliant for DD, very good for track.
TL;DR Buy something designed for your use, not one size fits all.
https://mcasuspension.com/suspension
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 12-30-2018, 11:16 PM   #21
kev0
Drives: '14
I settled for Bilstein B8's with RCE Tarmac Springs (brown). The ride feels.. better?
kev0 is offline   Reply With Quote
Old 12-31-2018, 01:28 AM   #22
jflogerzi
jflogerzi's Avatar
You tell us? That's a really good combo.
2013 Series 10 FRS #553
What Are Your Pet Peeves of Daily Driving (Your FRS/86)? Little Mt. Fuji Scion FR-S / Toyota 86 GT86 General Forum 100 11-16-2018 06:16 PM
Daily Driving/Spirited Driving Brakes VABeachBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-12-2017 05:11 PM
Best Tires for Daily Driving Fun tez2013 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-31-2016 07:11 PM
Best coilovers for daily driving/durability Hentai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-24-2015 02:32 PM
MSSP PSI for daily driving? jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-17-2014 09:49 PM
