Old 09-18-2018, 01:20 PM   #15
Grady
Grady's Avatar
That is just it. It is engineered into the system. That does not mean you can take a system that was not engineered for it and expect the same results.
Those pops and crackles are explosions occurring where the parts are not designed for explosions. I have never seen good results from such actions.
Remember the day when cruising you would just turn the key off for a second or 2 then turn it back on? That was a real backfire! Watch my friend blow the muffler right off of his moms car doing that!
Old 09-18-2018, 01:51 PM   #16
It's just unburnt fuel being dumped into the manifold. Worst thing it might do is deposit more carbon in the exhaust or reduce the lifespan of the cat, or both. Cheap to fix. Worth the fun. My catback pops sometimes.
No those are not the "worst" that can happen. This is not a risk free mod but as long as people understand and accept the risk and responsibility then all is good. I just doubt that many would. Blow a valve and it will be another "damn crappy Subaru engines they need to cover this under warranty or we should sue" scenario.
Old 09-19-2018, 12:40 AM   #17
Brayden_23
Drives: Asphalt 2015 FRS
I ran this tune for a bit for the fun of it. Ended up fouling my O2 sensor for my AFR gauge - I haven't checked the condition of the other sensors. I was running it at 2500 rpm and up. Ended up dialing it back to only when I'm above 5k. Now it's more of a surprise when it occurs, and often out on track adding that much more entertainment.
Brayden_23 is offline   Reply With Quote
Old 09-19-2018, 02:46 AM   #18
gt7877
Drives: turbo frs
This can coze O2 sensore damage after long term
gt7877 is offline   Reply With Quote
Old 09-19-2018, 08:04 AM   #19
Tokay444
Anti stance.
Tokay444's Avatar
Backfires happen in the intake manifold though...
Old 09-19-2018, 07:53 PM   #20
Some are in the intake and some are in the exhaust. There is a different name for the exhaust ones but I don't remember what it is and most just call them all "backfires" anyway. Both are just explosions outside of the combustion chamber but the exhaust ones tend to be more spectacular. Sort of like burping versus farting.
Old 09-19-2018, 08:27 PM   #21
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
OR fouling O2 sensors, burning valves up, or blowing muffler packing out. All things that have been seen with this tune edit....
Old 09-19-2018, 10:48 PM   #22
sroby
Drives: 2015 Firestorm 08/05/15
About as useless as Harley riders quotes. Loud pipes saves life’s. B. S. Gives our platform unwanted notice. Not to mention it sounds like crap
sroby is offline   Reply With Quote
Old 09-20-2018, 08:33 AM   #23
Tokay444
Anti stance.
Tokay444's Avatar
Ones in the exhaust are after fires, because they happen after the combustion chamber.
The two terms are NOT the same thing and are NOT interchangeable.
Old 09-20-2018, 08:45 AM   #24
Both are the ignition of fuel outside of the combustion chamber. Whether before or after they are the same concept. Correct or not the term "backfire" has been used for both forever.
Old 09-20-2018, 09:21 AM   #25
Tokay444
Anti stance.
Tokay444's Avatar
Wrong is still wrong, no matter the length of perpetuation.
One is generally relatively harmless if it only happens occasionally.
The other will almost always result in catastrophic engine failure the first time it happens.
Old 09-20-2018, 12:32 PM   #26
fang_gt86
FR Noob
fang_gt86's Avatar
Depends on how you look at it. Remember Toyota have to give the Prius "artificial" noise so blind and text-while-walking zombies don't get hit. I personally see my exhaust noise as a safety feature. Thanks to my loud rumble, I've avoided couple near misses. The pop and crackles still not for me though..
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 09-20-2018, 02:27 PM   #27
Tokay444
Anti stance.
Tokay444's Avatar
Dumbest trend in the automotive industry after stance.
Old 09-20-2018, 02:29 PM   #28
Icecreamtruk
Drives: Track preped NA FRS
So what you are saying is farting is more spectacular than burping? I knew I was right all along!
pops tune, tune
OFT Pops and Crackle Tune problem V4 niceman Software Tuning 8 09-16-2018 09:27 PM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
OFT Pops and Crackle Tune just stops working after a while? stig_iv Software Tuning 12 08-21-2018 05:30 PM
Question about crackle and pop.. Qc86 Engine, Exhaust, Transmission 10 12-03-2017 01:49 PM
Exhaust crackle and pop? Kiwi Engine, Exhaust, Transmission 19 03-22-2013 03:14 PM
