Old 08-13-2020, 03:51 AM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by D-VO View Post
@steve99 Any ideas for me? I looked through some of the ROMRaider stuff but can't find then posted or in the 32bitbase.
If you're half decent with a computer, use this:
ScoobyROM
I used that to create a lot of my defs, in fact try and see if I did it for A01C:
K47 A01C Def
The locations between similar ROMs will not be far off, so take the 2 parts of the info from the B01C and all you should need to change is the address.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-14-2020, 06:37 AM   #16
steve99
what ecu calud you trying to efit ?
Old 08-14-2020, 08:35 AM   #17
D-VO
Drives: Whiteout FR-S, Evo 8 RS
ScoobyROM
K47 A01C Def
The tables are in there but the addresses and scalers are missing. 😔 I guess I have to figure out the program you shared. Thanks.
D-VO is offline   Reply With Quote
Old 08-14-2020, 06:45 PM   #18
D-VO
ZA1JA01C.
Old 08-15-2020, 08:18 AM   #19
steve99
ZA1JA01C.
ok ill see if i have defs with those maf coreection tables
alternative would be to use a B01C or an A01G rom as a substitute which definitly have those tables defined
Old 08-15-2020, 11:43 AM   #20
D-VO
ok ill see if i have defs with those maf correction tables
The B01C has a lot of tables that are not defined properly so I stopped using it. However, A01G you say? Hmm... I thinknI want to stay with A01C since it has most of what I use defined already. It's just missing the MAF correction after start tables.
*Edit* Tried A01G, car wouldn't start. i dont know if I missed a table or a setting was wrong but the car would not start. I ended up using ROMraider for the MAF correction tables to display properly. I'm still not able to properly define the scaling unit call "Mode Counter" for ECUFlash.
Old 08-15-2020, 05:01 PM   #21
Kodename47
Kodename47's Avatar
Drives: UK GT86
@D-VO if you want B01C then I pretty much defined all the tables ages ago:
K47 B01C Definition
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-16-2020, 05:04 PM   #22
Contender
Drives: 2017 Toyota 86
I hated cold start even before I went catless sounded retarded...
Contender is offline   Reply With Quote
need help to lower cold start w/OFT stage 1 vietspride70 Software Tuning 1 06-02-2021 03:17 AM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
