Old 04-11-2018, 04:20 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had similar issues when I went to 245 RS3's on my mostly stock suspension. The car would body roll and load up, then the rear would let go under hard cornering. On Flez Z's now, car much more planted.
Old 04-11-2018, 04:44 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Do you run TC on track? Try it off. It is very invasive and actually feels less stable then with TC off imo.
Old 04-11-2018, 05:11 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Harey View Post
My wheel alignment settings are:
Front Camber -2
Front Toe +0.5
Caster 6 degrees 12 minutes
SAI 17 degrees 18 minutes
Rear Camber -1.3
Rear Toe +1.0
Toe-in is in millimeters I trust? If so, that's fine (about 0.05° front and 0.10° rear), could run zero though.
I'd go with a front sway bar to balance handling, that will take advantage of the added front camber and provide more grip at the rear of the car.
Old 04-11-2018, 07:33 PM   #18
Harey
Drives: 2013 Toyota 86
Wow thanks for all the posts, lots of good info there.
I definitely agree that the additional front camber has made my car faster, its not a complaint. Its more of a what to do next question.
The rear toe is +1.0 degree (toe-in) which was intentionally added by the guy who did my wheel alignment to reduce oversteer and add high speed stability (which he does to all of his twins with great success).
I realised I left out some information:
I only get the traction control engaging on the street. I have never had it occur on the track (and mostly turn it off when i remember to). TC engaging occurs in sharp bends on the street with less than ideal surfaces or a few bumps.
On the track the turn in is fantastic, I can always bring the front in but then for the rest of the corner it is about managing the rear traction. It definitely feels like I have way more grip in the front than in the rear. The rear has never kicked out on me but I am not pushing it to the limits.
My previous track car was a Subaru awd and it was a constant battle to turn in. I learnt how to trail brake which helped heaps. Complete opposite to this car which I feel like at the speed the rear can take the corner my front laughs at it.
There is definitely a lot of driver improvement to go. My main focus at the next track day will be feeding in throttle as I unwind the steering. However, I just feel mid corner with zero throttle and trying to balance front and rear grip there isnt as much driving skill (long corner), its more about the car. Corner entry and exit I completely agree that driving skill is massive.
Harey is offline   Reply With Quote
Old 04-11-2018, 07:38 PM   #19
Harey
Originally Posted by wparsons View Post
The balance of camber front to rear is actually decent. IMO, it's probably how you're driving that's causing it.
Does it happen if you're off the throttle, or does the rear kick out under power? Are you adding throttle without reducing steering input?
It happens on the street without any throttle but normally on a less than ideal surface sometimes with bumps. With less front end grip I couldnt take the corner as fast so the rear wasnt under the same stress.
I think the question is "Now I have more front end grip, how do I increase rear grip to match"
Old 04-11-2018, 07:39 PM   #20
strat61caster
strat61caster's Avatar
You shouldn't be at zero throttle mid-corner unless you're out for a leisurely Sunday drive or you screwed up.
ineedyourdiddly
wparsons (04-12-2018)
Old 04-11-2018, 07:41 PM   #21
Harey
Originally Posted by why? View Post
are the tires new? Are the rears worn more than the fronts?
Definitely need more rear camber.
All tyres purchased brand new last year with less than 3,000 miles on them. They are worn evenly front to rear.
Old 04-11-2018, 07:43 PM   #22
Harey
I thought if you are accelerating mid corner then your corner entry speed was too slow?
Old 04-11-2018, 07:48 PM   #23
Harey
Originally Posted by ls1ac View Post
I just thought I might mention one other possibility, sometimes at the track we would adjust the front for more bite and the driver would swear we had ruined the back. When in fact he would be turning in faster lap times. The front improved and the back did not ,but with the higher speeds the back was loose. The seat of the pants are not necessarily the best measuring device.
Completely agree with this, this is exactly what is occurring. It is definitely faster with the additional front negative camber.
Old 04-11-2018, 08:23 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Maintenance throttle.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
strat61caster (04-11-2018), Ultramaroon (04-13-2018), wparsons (04-12-2018)
Old 04-11-2018, 08:30 PM   #25
johan
Drives: '14 981CS, '99 NB1
MCA Traction Mod, easy to install and doesn't screw up your alignment. Also you're already in Australia so they're easy to procure.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Harey (04-11-2018)
Old 04-11-2018, 08:36 PM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
1° is an absurd amount of rear toe, way way WAY too much. Like 10x too much. And 0.5° is also a stupid high amount up front as well. Are you *sure* that's in degrees? If so, handling is guaranteed to be fuxored with those toe settings. Not to mention tire life...
Old 04-11-2018, 08:39 PM   #27
strat61caster
Well at the risk of derailing this thread to hell...
Saying "zero throttle" implies that your foot is off the pedal and the car is coasting and slowing down, maybe we're on the same page and just using different language and you do mean maintaining speed at apex which is something I would agree with and I apologize in advance for the misunderstanding and this wouldn't be new theory for you but it might help others. Most quick drivers are accelerating at or around the apex and using the rwd characteristics to complete the necessary amount of yaw, at a minimum there should be some amount of throttle input to maintain speed in a perfect theoretical corner. Of course some corners will be exceptions depending on what's happening.
2:00-2:30 you can see the throttle being fed in well before the apex of each corner.
[ame="https://www.youtube.com/watch?v=NtaV_cOGgTM"]Schumacher's driving style explainded - YouTube[/ame]
Recent Lewis Hamilton lap:
[ame="https://www.youtube.com/watch?v=zJRh9FG83d0"]F1 2017 v 2016: G-Force Comparison - YouTube[/ame]
There's some amount of throttle being used pre-apex at just about every corner as good drivers are 'balancing' the car and finding the limits, great drivers nail the speed on the braking and are just maintaining until they know they have the grip to accelerate.
But we're not F1 drivers. It's a bit harder to find telemetry of street cars with known good drivers, this should do. The key here is there's no drop in speed after braking is completed, that doesn't happen with your foot off the throttle unless you're using cruise control. Given that we're mostly amateurs doing HPDE's and such, it's safer to brake a little too much and begin picking up speed, but with enough practice we can have data that looks as good as the fast guys.
[ame="https://www.youtube.com/watch?v=38WqRJf7So8"]2013 Subaru BRZ Hot Lap! - 2012 Best Driver's Car Contender - YouTube[/ame]
Or this is a good example too:
[ame="https://www.youtube.com/watch?v=HlwAIb4Zz9Y"]Fastest Lap at Toronto Motorsports Park In a Scion FR-S - YouTube[/ame]
YouTube has a great feature that allows you to slow down the video so you can get a better understanding (in this case) of speed relative to car position.
ineedyourdiddly
Old 04-11-2018, 09:32 PM   #28
Harey
Woops yeah your right its in mm not degrees.
The Following 2 Users Say Thank You to Harey For This Useful Post:
strat61caster (04-11-2018), wparsons (04-12-2018)
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Negative Camber! victorchav Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-08-2016 12:51 PM
Negative front camber? Estey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-23-2014 06:33 PM
What are your opinions on negative camber, from a looks perspective? 86-tundra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 12-26-2013 01:29 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
