Old 08-14-2019, 10:59 PM   #15
ZionsWrath
Thanks
ZionsWrath's Avatar
You probably bought the ball joint tool as your post said the Harbor freight tool worked perfectly
Old 08-15-2019, 05:03 AM   #16
Phuviano
Drives: FRS RS 2.0 #757
Originally Posted by GrantedTaken View Post
In case I need to do this again, I am trying to remember how I REMOVED the busted stud.
Do you think I just hammered it out? I know hammering on the hub is not the best idea.
Only got my car 3 months ago, but came with a broken stud. I hammered it out with ease. I used a normal mallet. I gave it two light hits, and it popped right out. I really didn't hit it hard at all. The mallet didn't even touch the hub.
I don't know if they all come out that easy, but that was my experience.
Phuviano is offline   Reply With Quote
Old 08-15-2019, 10:11 AM   #17
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Instead of using washers, you might consider using a specialized tool:
https://www.amazon.com/gp/product/B000ETUD22
One of the reviews on Amazon specifically says this worked great on a BRZ.
I'd also be curious to learn if there's a better way/tool to pull an old stud other than basically whacking it with a hammer.
timurrrr is offline   Reply With Quote
Old 08-15-2019, 10:30 AM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There is; I mentioned it already in this thread.
I LIKE TIRES!
Old 08-15-2019, 10:50 AM   #19
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Ok, did some search on YouTube this looks like the best option:
Did you mean this tool or the one that looks more like
Old 08-15-2019, 10:51 AM   #20
GrantedTaken
Washers are perfectly fine.
The tool adds no real value.
GrantedTaken is offline   Reply With Quote
Old 08-15-2019, 10:56 AM   #21
GrantedTaken
Good catch, I missed that.
Ok, the HF ball joint tool is probably better than bashing the hub.
https://www.harborfreight.com/3-4-qu...tor-99849.html
I now remember bashing the rotor to get it off.
My car's at 50k with OEM brakes
Maybe it's time to replace the pads.
Rotors should be fine.
How do you check rotor width?
Are there markings on the rotor?
Old 08-15-2019, 11:17 AM   #22
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, like in the video. It works easy for install and removal. I have upgraded all of my studs with the same tool.
FYI...
You will also need a big socket (36mm IIRC) for the rear axle nut if you are replacing the rear studs with ones that are longer than OEM +5mm.
I LIKE TIRES!
Old 08-15-2019, 11:55 AM   #23
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I used this tool. Works perfectly. I had about 3-4 OEM Studs break on me and use Dorman now.
Clueless
YamahaR86 is offline   Reply With Quote
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 08:20 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Wheel stud options chris86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-26-2014 02:40 PM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 01:58 PM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
