#15 |
Drives: 2014 brz limited
Tires are good but the brand ive never heard of it before.
#16 |
Drives: 2015 Scion FRS 6MT (Asphalt)
For anyone looking to give a hand at solving this, these are his alignment specs (I'm uploading them for him).
![]() Sent from my iPhone using Tapatalk |
#17 |
The Dictater
Drives: '13 Red Scion FRS
Alright, I'll ask it. What are your tire pressures at OP?
#18 |
40psi front and rear
#19 |
The Dictater
#20 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Does this happen turning left and right? I know most offramps are right turns but Im wondering if the caster plays a roll since its so far off? Im kinda a suspension noob and just thinking out loud though
#21 |
#22 |
Ill try and find a left turn that gives me the same results
#23 |
Tire pressure didn't help
#24 |
Panda Trueno
Drives: No twin now.
Are your rear tires sitting in the wheel wells evenly when you look at from the rear. Are you sure nothing is shifted / bent? What was damaged in the accident?
#25 |
They do. What was damaged was the front suspension slightly. They needed a camber bolt to get it within specs.
#26 |
The Dictater
#27 | |
Ill give the front sway a once over i only checked the rear since i thought the problem would be in the rear. |
| The Following User Says Thank You to Brzlimited661 For This Useful Post: | Ultramaroon (02-10-2018) |
| Car swaying left right (floating feeling) highway speeds | FX86 | Issues | Warranty | Recalls / TSB | 37 | 05-30-2021 11:48 AM |
| Hood lift at high speeds | Basti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 97 | 02-15-2016 03:50 PM |
| weird issue at high speeds after OFT tune | dejxx | Software Tuning | 24 | 08-10-2014 09:49 PM |
| feeling a sway on the rear end | qganja | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-25-2013 03:56 PM |
| High pitch sound at freeway speeds | l0aded | Issues | Warranty | Recalls / TSB | 7 | 06-14-2013 05:25 AM |
