Old 02-06-2018, 05:41 PM   #15
Brzlimited661
Drives: 2014 brz limited
Tires are good but the brand ive never heard of it before.
Brzlimited661 is offline   Reply With Quote
Old 02-06-2018, 05:54 PM   #16
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
For anyone looking to give a hand at solving this, these are his alignment specs (I'm uploading them for him).
NAEightySix is offline   Reply With Quote
Old 02-06-2018, 06:10 PM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Alright, I'll ask it. What are your tire pressures at OP?
Old 02-06-2018, 06:13 PM   #18
Brzlimited661
40psi front and rear
Old 02-06-2018, 06:16 PM   #19
Spuds
The Dictater
Spuds's Avatar
I bet the problem goes away when you set them to 35 psi front and rear.
Old 02-06-2018, 06:17 PM   #20
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Does this happen turning left and right? I know most offramps are right turns but Im wondering if the caster plays a roll since its so far off? Im kinda a suspension noob and just thinking out loud though
Old 02-06-2018, 06:17 PM   #21
Brzlimited661
Ill try it
Old 02-06-2018, 06:21 PM   #22
Brzlimited661
Ill try and find a left turn that gives me the same results
Old 02-06-2018, 06:42 PM   #23
Brzlimited661
Tire pressure didn't help
Old 02-06-2018, 06:47 PM   #24
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Are your rear tires sitting in the wheel wells evenly when you look at from the rear. Are you sure nothing is shifted / bent? What was damaged in the accident?
Old 02-06-2018, 07:01 PM   #25
Brzlimited661
They do. What was damaged was the front suspension slightly. They needed a camber bolt to get it within specs.
Old 02-06-2018, 07:06 PM   #26
Spuds
The Dictater
Spuds's Avatar
But at least you're now at recommended pressures.
How are the sway bars? Everything look ok on them? Maybe the front sway bar yielded in the accident and now your rears are trying to do too much work?
Old 02-06-2018, 07:10 PM   #27
Brzlimited661
Thats true thank you
Ill give the front sway a once over i only checked the rear since i thought the problem would be in the rear.
The Following User Says Thank You to Brzlimited661 For This Useful Post:
Ultramaroon (02-10-2018)
Old 02-06-2018, 08:13 PM   #28
Summerwolf
Panda Trueno
Summerwolf's Avatar
Then it most likely still has something tweaked in the front, which could definitely affect the cars handling.
The Following User Says Thank You to Summerwolf For This Useful Post:
Spuds (02-06-2018)
Car swaying left right (floating feeling) highway speeds FX86 Issues | Warranty | Recalls / TSB 37 05-30-2021 11:48 AM
Hood lift at high speeds Basti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 97 02-15-2016 03:50 PM
weird issue at high speeds after OFT tune dejxx Software Tuning 24 08-10-2014 09:49 PM
feeling a sway on the rear end qganja Scion FR-S / Toyota 86 GT86 General Forum 11 07-25-2013 03:56 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 05:25 AM
