#15 | ||||
Hopefully the shop did a good job and got those toe links torqued correctly and everything is hunky-dory from here on out. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Target70 (01-09-2018), Ultramaroon (01-08-2018) |
#16 | ||
Drives: 2014 GT86
Hence even if one is not planning to ever track, it's very worth it to get good alignment. Good performance shop should be able to tune alignment camber within +/- 0.05, and toe within +/-0.01 (at least if you have added camber tuning options (our cars stock have only toe adjustment) with eg. adding camberbolts and rear LCA (as there are sometimes limits how much one may adjust with no stock adjustment, only with slack in mounting bolts, and as toe-camber changes are linked)). For example, this is my printout. Of course, you can ignore excessive overall negative camber, which is dialed to tailor car more for track, but see differences in right/left, for camber and toe. Now compare to 'allowed' +/- for stock: Quote:
#17 | |
See, I believe in finding a local shop, where I can get to know the people and they get to know me. For example, I've been going to a local tire/auto shop here in Puyallup for about 25 years. I pretty much know what I want to buy and what I want done when I take a car in ....... and they know me well enough that they best do it right. Now, that's not to say, that if had a car that I tracked, I might be tempted to take it into a specialty shop for suspension and wheel work. ![]() humfrz |
#18 |
Drives: 2014 GT86
humfrz: i live in very small country. There are not many shops around, thus my observations might be wrong/too pessimistic, and experience non objective. But so far it's been like:
Dealerships imho most commonly do well only with stock stuff / stock parts / stock maintenance procedures and often botch things when one wishes something outside those bounds. They often also charge too much. Tire shops and alikes .. if alignment is something like freebie or extra thrown in/offered alongside their main business, they have less motivation/less devoted time to do it pedantically right. They often also sell (tires) in big numbers to high customer counts, and have incentive to deal with customers quicker and care less if small count of them is left dissatisfied or if most don't care. They can reel more customers via main business, selling tires, by eg. slight price drops, then with offered high quality alignment job. Performance shops, where customers turn to with those specific wishes to get wanted performance/handling change, specialize more on that. They also are more motivated to quality job to turn smaller count of customers to regular ones and gain free personal-advertising of them to customers' friends/relatives/acquaintances. Also they can advise/suggest/reason more performance oriented configurations according to their expertise of improving performance of client vehicles and according to what client wishes to get. Of course, there can be exceptions to any of these type of places offering to check/tune alignment. Hence probably best bet would be browsing local forums and find shops/places that do quality job according to experiences of others and try few of them from gathered list, and if one is happy with service and prices, just stick with that place/those techs. |
| The Following User Says Thank You to churchx For This Useful Post: | humfrz (01-09-2018) |
#19 | ||
Drives: 2013 Asphalt 6spd
No drifting and no pulling. The car tracked straight as an arrow, I could take my hands off the wheel without issue. Thank You, I hope this handles it . Quote:
I wonder though, if the factory toe arms suck at holding in place, is that the fault of the eccentric bolts in general, or just the ones the factory used? Also assuming they do, why would the SPC LCAs with the eccentric bolts stay in place when the stock toe arm's don't? I found the SPC adjustable toe arms over at speedfactory at a reasonable price assuming I had to replace mine if one was bent. I don't see any instructions, but if the video on the LCAs are any indication they will use the factory mounting hardware, which means the stock eccentric bolts that won't stay in place. Does that mean I would also need to buy the SPL eccentric lockout kit?
#20 | |
Drives: 2013 satin white brz limited
Have you checked with discount tire? They are running a sale on the currently. If you purchase using their discount tire card you get a total of $120 back in rebates. If you choose to not use their card you still get back $70 in rebates.
https://www.discounttiredirect.com/b...-sport/p/35430 Quote:
| The Following User Says Thank You to jasonojordan For This Useful Post: | Target70 (01-09-2018) |
#21 | |
#22 | |
I think you are way to hung up on this needing to be done at one place. |
#23 |
It's not that I'm hung up about it, it's that I don't know of a lot of options. I've got 3 "reputable" places, that actually do alignments, 2 if ignore the one that told me that his 30 years of experience say he will have to realign it after I get new tires. These are not the kind of places you even get to talk to the mechanic. you drop your key off at the desk and the car vanishes, you see it when they are done. I have previously pissed off the guys at the dealership by walking around the back and watching through a roll-up. Hell if I could I would be in there helping them, or doing it myself.
#24 | |
| The Following 2 Users Say Thank You to jasonojordan For This Useful Post: | strat61caster (01-09-2018), Target70 (01-09-2018) |
#25 |
Definitely check your local region on here and on nasioc.com.
- Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | strat61caster (01-09-2018), Target70 (01-09-2018) |
#26 | |
.https://forums.nasioc.com/forums/forumdisplay.php?f=21 but my local Toyota/Scion dealership made the "Dealerships to AVOID in the SE" thread, so I got that going for me, which is nice.
#27 | |
#28 | |
humfrz |
| Quoted $750 for a paint chip repair - Need advice | James Russels | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 17 | 08-24-2017 10:40 PM |
| Camber/alignment for Eibach Prokit and when should I get alignment? | Meanderchap | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-01-2016 03:44 AM |
| DIY alignment - quick way to set alignment while new suspension settles? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-11-2014 09:53 PM |
| Seeking Advice! Swift BRZ, Alignment! | leicaboss | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-27-2014 03:23 PM |
| Dealer damages car during warranty repair, need advice. | rhythmM | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 01-07-2014 12:04 AM |
