Old 03-27-2014, 11:55 AM   #1
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Thumbs up Seeking Advice! Swift BRZ, Alignment!
Hey all,
I finally got around to getting my Swift Springs and SPC Rear Control Arms + Front Camber Bolts installed. Totally expected my alignment to be off, but this time it was exceptionally bad to the point where it frequently triggers my VSC to kick in and it'll start braking for me in low speed turns. Car is horribly "floaty" and unstable right now, so alignment is happening today! With that said I am in dire need of some proper guidance from you knowledgable folks.
I'm looking for handling that's at least as tight as it was stock (BRZ) but can take on the twisty canyon roads with greater confidence than before. I believe my SPC front camber gives me (1.75 +/-) of camber, and the rear is (2.00 +/-). I realize it's not too much to work with... though correct me if those SPC specs are wrong.
  • Swift Springs BRZ Spec; lowered 1" [Front: 3.8/kg - Rear: 4.5/kg]
  • Most of my driving will be on the highway (commuting)
  • Spirited weekend driving up in the "twisties"
  • Occasional track and AutoX usage (May 9th @ Thunderhill HPDE, for example)
  • Seeking handling that is a bit more tame - noob friendly!
The alignment guy briefly said that a tiny bit of toe in the rear would be good, but I'm not sure if thats desirable, doesn't toe-in in the rear kill my tires?
Anyway, I appreciate any advice you can provide on a somewhat "all-around" alignment setting given my options. I would appreciate input on how to deal with alignment guys too, to make sure I get what I want.
Thanks so much!
David
PS - tagging the smartest kids in town @Racecomp Engineering @CSG Mike
leicaboss is offline   Reply With Quote
Old 03-27-2014, 12:26 PM   #2
wparsons
wparsons's Avatar
Excessive toe will kill your tires, but a tiny bit won't be bad (like 1/16"). Running zero rear toe will make the car rotate more at turn in, but also feel less stable. The BRZ's come with a bit of rear toe stock, so keeping it inline with the stock spec probably isn't a bad thing to start with.
flickr
Old 03-27-2014, 12:47 PM   #3
Max out your front camber via the bolts, and then run a tad less (0.25 to 0.4 less) in the rear. 0 toe front and rear.
Old 03-27-2014, 01:13 PM   #4
leicaboss
Coffee Snob
leicaboss's Avatar
Thanks guys, I appreciate it.
@CSG Mike - If you don't mind, could you help explain your reasoning for 0 on toe all around? Just out of curiosity; I'd love to understand the thought process behind this. Ugh, if I lived in SoCal would've gone to you guys for everything.
Old 03-27-2014, 03:23 PM   #5
While there is some dynamic toe change, it's not enough to really warrant running static toe. Likewise, the car doesn't exactly have a ton of power, so toe-in on the rear isn't necessary to promote stability.
Toe also scrubs the tires, sapping power, and this car needs every bit of power it can get.
Last but not least, the car is stable under static cornering, so no need for toe-in to stabilize the rear. Some setups actually benefit from a tiny bit of toe-out.
We can always ship to you, and there's no sales tax since you're out of state
alignment, brz, camber, swift, toe
Student seeking an internship Sterz Southern California 21 03-02-2014 03:10 PM
Seeking FR-S/BRZ for Product R&D Shadow Blue Northwest 7 08-21-2013 09:38 PM
Alignment question after swift sprigns SliverBrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-19-2013 10:03 PM
Seeking Opinions: 17x9.5 +40 and 245/40/17 B L U E S L A T E Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-21-2013 04:07 AM
Seeking UK brochures DarrenDriven EUROPE 11 10-23-2012 11:42 AM
