Old 09-08-2017, 07:11 PM   #15
sfruski
Drives: Many
Progress! I took our the fuel canister and found the fuel pressure regulator rolling around in the bucket.
I put that back in place and how I have fuel getting to the engine!
Unfortunately one of these two hoses are leaking in the engine bay. Can i just replace it with hose clamps and fuel line?
sfruski is offline   Reply With Quote
Old 09-10-2017, 05:20 AM   #16
FRS Justin
Drives: 2013 Asphalt FRS
I wouldn't, if it should come off when driving you will have a nasty fire. try to get a replacement. but first take it off and put it back on to see if it fixes it
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
wparsons (09-10-2017)
Lean Code/Weird fuel trims jwvand02 Issues | Warranty | Recalls / TSB 18 03-24-2017 03:06 PM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 09:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 04:52 PM
code P1604 possible fix? (start ability malfunction) tjsmooth25 Scion FR-S / Toyota 86 GT86 General Forum 7 06-25-2014 06:39 PM
Engine Check Light: P1604 Startability Malfunction alakim Engine, Exhaust, Transmission 5 09-09-2013 09:46 AM
