Old 03-19-2017, 09:36 PM   #1
jwvand02
Drives: 2013 SWP BRZ Limited
Lean Code/Weird fuel trims
So I put the car back to stock in order to sell it. It popped a P0174 code, and so I went to investigate. This has been a long running issue with the car, but thought it was solved. It has an aftermarket header that I have long suspected to be the culprit, which I found a crack in at one point but had it fixed.
The behavior it's exhibiting now - LTFT is extremely high, 20-22% but only under no or very little throttle. Any throttle and LTFT goes to 0. STFT are within 1-2% under all conditions. I checked under the car, and lo and behold I found a nut missing from the header that I guess I didn't torque properly at some point. I fixed that problem, and assume that is the cause. I pulled the positive battery cable for about an hour under the assumption that it would reset the fuel trims.
There's no obvious sign of misfire or knock, the car doesn't appear to be pulling timing. My next thing to do is just to put the stock header back on.
I guess I have two questions:
1. Is it possible that the fuel trims didn't reset and that the LTFT will come down over time?
2. Am I barking up the wrong tree chasing after the header? I don't really hear any signs of an exhaust leak, but I'm close to positive there's no vacuum leak because I was extremely careful when assembling the intake.
2013 SWP BRZ Limted
Innovate Stage 2
E85, Tuned by Moto-East
jwvand02 is offline   Reply With Quote
Old 03-20-2017, 04:49 AM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
the high LTFT at idle and going to near 0 with any throttle sounds like either an exhaust or vacuum leak. How are the header gaskets- what gaskets did you use? Make sure there's no leak in the PCV or brake booster lines. If you have a catch can, check that.
But it sounds like a header gasket issue to me.
Old 03-20-2017, 08:19 AM   #3
steve99
as above guy said If the LTFT is high positive at low rpm and ok at higher rpm and the afr is ok at higher rpm.
then its most likely an exhaust leak gaskets crack or leak at front 02 sensor itself
Old 03-20-2017, 09:40 AM   #4
jwvand02
Yeah... that's my thought process too. I guess I will put the stock header on tonight and see if that fixes the problem.
2013 SWP BRZ Limted
Innovate Stage 2
Old 03-20-2017, 11:30 AM   #5
steve99
Use new gaskets, re-used ones almost always leak
Old 03-20-2017, 12:51 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
You didn't use new header gaskets did you? Get the Grimmspeed gaskets, they are cheaper and better than OEM
Old 03-20-2017, 04:39 PM   #7
jwvand02
I did when I installed the header the first time (grimmspeed gaskets), but now I don't know if there's additionally an issue with the header itself. If the header works fine and it's the gaskets I'd rather use it, but at this point not sure there's any point.
2013 SWP BRZ Limted
Innovate Stage 2
Old 03-22-2017, 01:21 PM   #8
jwvand02
Installed the stock header with brand new gaskets last night.
No change long term fuel trim is still ~19% at idle or coast, and drop to zero with even the slightest bit of throttle.
I did try leaving the positive cable off overnight to reset things, not sure if that actually works or not. I'm considering re-flashing the ECU. I guess I may have to spend the evening rigging up a smoke machine to double check for vacuum leaks...
2013 SWP BRZ Limted
Innovate Stage 2
Old 03-22-2017, 07:14 PM   #9
steve99
is the trim LTFT +19 or -19 ?
at idle is the measured AFR about 14.7 ? and steady at around 14.7 or is it moving around considerable like to 12 then 15 for example
Old 03-22-2017, 08:44 PM   #10
zackegle
Drives: 2013 brz limited
i have the same lean issue except my car is stock besides oft stage 1 tune, my ltft is way high
could someone look at my data log and possibly help me figure out whats wrong?
https://drive.google.com/open?id=0B1...3J3SFdMbk5KWHM
zackegle is offline   Reply With Quote
Old 03-22-2017, 08:46 PM   #11
jwvand02
So, I'm here to eat crow. You know how I said I was almost positive there were no vacuum leaks?
I gave up and tore the top end apart again... wrong size hose clamp on the evap solenoid, the hose slid right off. I guess that's what arrogance gets you. Once I fixed that... fuel trim is down to about +4% at idle. Not perfect, but I can live with that for sure.
2013 SWP BRZ Limted
Innovate Stage 2
Old 03-22-2017, 10:18 PM   #12
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
What fuel are you running? Your AFRs are very high - I would flash back to stock mapping until you know what's going on.
Also, I know you said "stock," but I just want to make sure...you haven't changed your intake system at all, have you? Your MAF voltage isn't responding as aggressively as I would expect during your higher RPM runs.
theadmiral976 is offline   Reply With Quote
Old 03-23-2017, 06:06 AM   #13
guybo
Huge E85 fan!
guybo's Avatar
It's hard to tell from such a small log and only revving up to the 3000's, but that car is running lean, I wouldn't go WOT with that. Fuel pump pressure logs would help. But without a CEL, I can't say for sure but this looks like a fuel system issue. Either one of the fuel pumps or an injector. What other symptoms are you getting?
Old 03-23-2017, 02:44 PM   #14
guybo
Huge E85 fan!
guybo's Avatar
I found your other thread about this issue. You're throwing lean and direct injector codes. You also had some plastic stuck in your throttle body. I wonder how plastic got in your intake. I'd start by tearing down the entire intake and checking out how that happened. Normally with a fuel issue, you swap injectors from one bank to the other and see if the problem follows. But on this car I don't know how difficult that is
Possible vacuum leak? (Running lean and high fuel trims) nickw14 Engine, Exhaust, Transmission 6 02-10-2023 10:56 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
Fuel trims are f***** up tskaohu Software Tuning 11 02-23-2016 09:53 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
