Old 02-09-2021, 12:01 AM   #15
thpark93
Drives: 2016 Asphalt FR-S
reviving this:
Did anyone install ducting for the radiator or intake?
Looking at this and wondering what the impacts are for the ACE product
https://aceheader.com/86-STOCK-RADIA...OOP-p133843655
thpark93 is offline   Reply With Quote
Old 02-09-2021, 08:26 AM   #16
czellers
czellers's Avatar
Drives: 2K19 GT86
Originally Posted by Icecreamtruk View Post
Hood vents, what you need are hood vents.
This is EXACTLY what I was going to say as well.. My next purchase is a heavily vented CFH.
czellers is offline   Reply With Quote
Old 02-11-2021, 12:47 AM   #17
thpark93
Ehhh, are you sure about hood vents? I haven't seen any data on this. If anything, I have seen empirical data that it doesn't actually help. You can take off the whole hood if you want.
In essence, the hood shouldn't restrict airflow. I'd be happy if someone can share what they know about it.
Sent from my Pixel 5 using Tapatalk
Old 02-11-2021, 01:49 AM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm. Data from CSG may do?
Old 03-21-2022, 04:10 AM   #19
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
This is still in the early development phase, but I'm working on my own ducting. Aim is to get my LS swap colled for drifting and track and as well keeping temps under control while sitting in a traffic jam and AC running @+100F.
My car is fully loaded and a daily driver mainly. AC installed, but this should work also on no AC appilcations. It will be made for the Gen1 86 (FRS) bumper. Features a front mounted 10 row oil cooler. Didnt want to cut the bumper, fog light openings will be used for brake ducting. (BTW, I also made custom vented backing plates for my BBK)
Once its done I maybe can give some numbers, but will not be a scientific assessment. A vented hood and a diffusor is also installed the same time, so it will be hard to identify exactly which gain was made by which components.
TRS is offline   Reply With Quote
Old 03-29-2022, 08:28 AM   #20
e21jason
Drives: GT86 TRD Cup
I built one, part of the reason for the bash bar was to make the ducting simple. No ac and run the forester cooler. Summer track days are over 40Deg C (104f) and the car used to overheat after a few laps. but with the ducted rad and hood vents i overheat before the car.
e21jason is offline   Reply With Quote
Full Air Ducting thejevans Cosmetic Modification (Interior/Exterior/Lighting) 2 02-13-2021 01:47 PM
Brake Ducting CHEAP! MR2 MK1 to FRS Newbie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-25-2015 10:49 AM
BRZ Premium custom brake ducting ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-17-2015 09:01 PM
Brake Ducting/Hose Routing? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-13-2014 03:20 PM
Custom Brake Ducting. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-09-2012 08:50 PM
