#15 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Car Driving Rough (misfiring)
Bad picture new one is correct
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#16 |
if the AFR is close to 14.7 and stft is pretty stead at -3 looks ok. although with a single o2 sensor your either measuring the average of all four cylinders on some headers or a single cylinder on others due placement. so its possible you could have a dodgy injector on one cylinder does the car drive ok now ?? |
#17 | |
Just got another misfire message on cylinder 3. Think it's the injector? Running like crap. Sent from my iPhone using Tapatalk
#18 |
I'd buy an injector right now... Any recommendations?
Went to subie dealer and they weee out of stock. Sent from my iPhone using Tapatalk
#19 | |
might also be bad spark plug Plenty of turbo guys would have stock port injectors lying around maybe also any tune shops that do brz/86 work or car wreckers |
#20 | |
I heard replacing the spark plugs is a pain... I'll take a look at the install. Sent from my iPhone using Tapatalk
#21 |
#22 |
#23 |
In two weeks going to be living in WA. Sent from my iPhone using Tapatalk
#24 |
Huge E85 fan!
Drives: 2016 Scion FRS
If you just throw parts at this problem, you won't figure out what's wrong AND you'll waste a lot of money. Do yourself a favor- go to a garage and have them diagnose the issue and you do the work to replace the parts. You have no clue what may or may not be the issue and you have no way to properly test the good parts you are throwing away.
You need to test the parts before you replace them. You'll run out of money before you run out of guesses. |
#25 | |
Unfortunately most "shops" wont understand modified cars with Flex kits Electric superchargers on E85 with custom tunes. They will just blame the mods or tell you to go somewhere else. Coil pack is logical choice for misfire Cyl 3 indication unfortunately it can be direct/port injector or wiring or spark plugs. But shop is going to go through a lot of labour charge to swap out these, not many are going to have facilities to test injectors . and they have to pull them anyways. Difficult when its intermittent problem. |
#26 | |
In two weeks ....... you will be exposed to the sunshine till about November ..... then you won't see it again till about next May. Are you in the military .. ?? I hope you get your car fixed before you come up here ....... these cowboys up here, just love to run over little cars that stall ...... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sojhinn (07-30-2017) |
#27 | |
If the port injector doesn't work, I plan on finding a shop near by to fix it. My biggest issue is the short time frame. I have to be driving to WA on August 12.
#28 | |
Moving to Renton Highlands, working as a teacher in Lake Washington.
| The Following User Says Thank You to Sojhinn For This Useful Post: | humfrz (07-30-2017) |
| Ignition Coils - Misfiring Help | SmireyFase | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 11-10-2016 03:06 PM |
| Engine Misfiring and Stalling | FIREISFUN135 | Issues | Warranty | Recalls / TSB | 7 | 09-19-2016 04:19 PM |
| Rough day for my 86 | KiddCoast | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 33 | 03-23-2015 04:30 AM |
| Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon | WTF | Issues | Warranty | Recalls / TSB | 12 | 06-14-2014 11:40 PM |
| At 5,000kms and fuel injectors 2 & 4 are misfiring!!! | UnLeasHer | AUSTRALIA | 55 | 11-12-2012 05:41 AM |
