Old 07-29-2017, 09:29 PM   #15
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Car Driving Rough (misfiring)
Bad picture new one is correct
Installed Mods:
Old 07-29-2017, 09:33 PM   #16
steve99
Drives: FT86
Originally Posted by Sojhinn View Post
-3.12 for stft
if the AFR is close to 14.7 and stft is pretty stead at -3 looks ok.
although with a single o2 sensor your either measuring the average of all four cylinders on some headers or a single cylinder on others due placement.
so its possible you could have a dodgy injector on one cylinder
does the car drive ok now ??
Old 07-29-2017, 09:33 PM   #17
Sojhinn
Sojhinn's Avatar
Just got another misfire message on cylinder 3. Think it's the injector? Running like crap.
Installed Mods:
Old 07-29-2017, 09:35 PM   #18
Sojhinn
Sojhinn's Avatar
I'd buy an injector right now... Any recommendations?
Went to subie dealer and they weee out of stock.
Installed Mods:
Old 07-29-2017, 09:55 PM   #19
steve99
Drives: FT86
might also be bad spark plug
Plenty of turbo guys would have stock port injectors lying around
maybe also any tune shops that do brz/86 work
or car wreckers
Old 07-29-2017, 09:59 PM   #20
Sojhinn
Sojhinn's Avatar
or car wreckers
I heard replacing the spark plugs is a pain... I'll take a look at the install.
Installed Mods:
Old 07-29-2017, 10:00 PM   #21
Sojhinn
Sojhinn's Avatar
Also @steve99 I owe you a beer for your help.
Installed Mods:
Old 07-29-2017, 10:16 PM   #22
....... for being so helpful.
DAEMANO (07-29-2017), Sojhinn (07-29-2017)
Old 07-29-2017, 10:45 PM   #23
Sojhinn
Sojhinn's Avatar
In two weeks going to be living in WA.
Installed Mods:
Old 07-29-2017, 10:47 PM   #24
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If you just throw parts at this problem, you won't figure out what's wrong AND you'll waste a lot of money. Do yourself a favor- go to a garage and have them diagnose the issue and you do the work to replace the parts. You have no clue what may or may not be the issue and you have no way to properly test the good parts you are throwing away.
You need to test the parts before you replace them.
You'll run out of money before you run out of guesses.
guybo is offline   Reply With Quote
Old 07-29-2017, 11:07 PM   #25
steve99
Drives: FT86
Unfortunately most "shops" wont understand modified cars with Flex kits Electric superchargers on E85 with custom tunes. They will just blame the mods or tell you to go somewhere else.
Coil pack is logical choice for misfire Cyl 3 indication
unfortunately it can be direct/port injector or wiring or spark plugs. But shop is going to go through a lot of labour charge to swap out these, not many are going to have facilities to test injectors . and they have to pull them anyways. Difficult when its intermittent problem.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Old 07-29-2017, 11:38 PM   #26
Where in Washington .... ??
In two weeks ....... you will be exposed to the sunshine till about November ..... then you won't see it again till about next May.
Are you in the military .. ??
I hope you get your car fixed before you come up here ....... these cowboys up here, just love to run over little cars that stall ......
Old 07-29-2017, 11:39 PM   #27
Sojhinn
Sojhinn's Avatar
I actually took the car this morning to the dealership. They refused to work on the car due to the mods. So Im stuck either finding a shop for Monday or trying to repair it myself. I have done all the work on my car myself, and I don't mind trying to fix it. I'm pretty sure we narrowed down the issue, and I'll post here when it gets fixed.
If the port injector doesn't work, I plan on finding a shop near by to fix it.
My biggest issue is the short time frame. I have to be driving to WA on August 12.
Installed Mods:
Old 07-29-2017, 11:40 PM   #28
Sojhinn
Sojhinn's Avatar
Moving to Renton Highlands, working as a teacher in Lake Washington.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
humfrz (07-30-2017)
Ignition Coils - Misfiring Help SmireyFase Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 11-10-2016 02:06 PM
Engine Misfiring and Stalling FIREISFUN135 Issues | Warranty | Recalls / TSB 7 09-19-2016 03:19 PM
Rough day for my 86 KiddCoast Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 33 03-23-2015 03:30 AM
Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon WTF Issues | Warranty | Recalls / TSB 12 06-14-2014 10:40 PM
At 5,000kms and fuel injectors 2 & 4 are misfiring!!! UnLeasHer AUSTRALIA 55 11-12-2012 04:41 AM
