#15 | |
With the 45s you'll rub the wheels on the inside at full lock, it clears with a 5mm spacer but I know that's sketchy on stock studs, a 3mm might be enough but idk, you could always just be conscious and not go full lock when driving around on the 9s. |
#16 | ||
Drives: '15 BRZ RA
Depends your style and the car usage. Will you use the car only for canyon driving or also for autox/track? Do you prefer the car more flat and do you fill more confident like that? As others mentioned, Ohlins have softer spring rates and will give a considerable body roll. This does not mean that they will NOT grip. You'll just ride more on the tire sidewalls and if you are doing many laps, your tires will eventually give up because of higher temperatures. Quote:
| The Following User Says Thank You to nikitopo For This Useful Post: | Keenercarguy (07-10-2017) |
#17 |
Drives: 2013 Raven FR-S
Avoiding full wheel lock on 45's hasn't been enough for me to stop rubbing. Just had an AutoX event yesterday and noticed some pretty bad tire rub on the inside of the fender liner. Raised the ride height 1/8" and added a 3mm wheel spacer and will see if that helps. Have a feeling I may need to raise the ride height more, but don't feel like getting another alignment anytime soon.
#18 | |
Drives: 2017 BRZ
#19 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
I already have ARP extended studs on all four corners
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
#20 | |
Mountain Runner
I'm likely not dropping the BRZ more than 1.25 inches, I'll be running 235/40/17's Z2*specs in the front for steering feel (245's in the back), and probably about 2.8* of front camber. I don't think I'll rub with those specs
#21 | |
Mountain Runner
| The Following User Says Thank You to Keenercarguy For This Useful Post: | nikitopo (07-10-2017) |
#22 | |
Drives: Track preped NA FRS
| The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post: | Keenercarguy (07-10-2017), strat61caster (07-10-2017) |
#23 | |
Mountain Runner
What springrates did you go with on the 510's? How do you like them?
#24 |
#25 | |
#26 | |
Driver skill aside, I run similar times on 245 RS4 tires to one of the more experienced drivers in our group, who is running RCE T2s in 255 nittos NT01. His car seems better composed going over berms and big bumps, I have better exit speed (from the apex and on), it seems like I have more traction coming out of corners, or he is leaving traction on the table. Edit: stock sway bars, as I think its worth mentionning when comparing suspension setups. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Keenercarguy (07-10-2017) |
#27 | |
#28 | |
It seems like many fast autox guys (who don't broadcast their setup online) are stiffening the rear a touch, sometimes via swaybars, maybe not enough to compensate for the motion ratios, but I think the square spring rates will fade out of favor for competition use. Even spring rates is a solid starting point but I'd be surprised if it was the ultimate setup. I can feel the rear lagging over road bumps, it can't be the most planted setup out there. The stupid amounts of testing I would do if I had time and money ![]()
| Looking for budget AutoX and HPDE setup | Keenercarguy | Want-To-Buy Requests | 1 | 09-03-2016 07:53 PM |
| Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks | Kyogre | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 05-12-2015 05:59 PM |
| Koni yellow/RCE tarmac setup-initial review | ncmx5 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-12-2014 01:55 PM |
| WTB: Track / AutoX Wheel and Tire Setup | n8dog11914 | Wheels and Tires | 3 | 06-17-2013 07:42 PM |
| AutoX Parts Setup | NYC BRZ | Tracking / Autocross / HPDE / Drifting | 38 | 08-17-2012 06:42 PM |
