Old 08-13-2012, 05:08 PM   #1
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
AutoX Parts Setup
I figured I'd start a thread to see what everyone is running on their BRZ/FRSs for autocross/track days
SCCA CS/RTR
-225/45/17 Dunlop Star Specs on stock wheels.
-OE Camber Bolt (-1.2deg, 0.0 toe)
-K&N drop-in
-Hawk HP+ (part number is HB432N.661)
-ATE Super Blue fluid
I'm waiting on a front bar. I want to see someone else monkey with it first
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 08-13-2012, 05:09 PM   #2
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Add muffler delete to that. I have a "build" thread on NASIOC in the autocross section. I would skip the hawk, go with ferodo or stoptechs.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-13-2012, 05:13 PM   #3
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
I got the stoptech brake kit for 550 (pads, rotor, and stainless steel lines) for Autox and hpde. Should arrive next week.
mechaghost is offline   Reply With Quote
Old 08-13-2012, 05:16 PM   #4
ABQautoxer
ABQautoxer's Avatar
Of which you can't use for this topic. Only the pads that fit the OEM brakes.
TomR
Old 08-13-2012, 05:38 PM   #5
mechaghost
mechaghost's Avatar
My bad I just saw AutoX, I didnt see the class. disregard
Old 08-13-2012, 09:08 PM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I'd skip the super blue and go with their amber colored fluid - unless you want your brake reservoir to be dyed blue (keeping you from easily figuring out the brake level).
Anyone know if the front subframe has to be dropped for the front sway bar installation?
Don'y forget to do the model interchange to all the lighter Premium parts
celica73 is offline   Reply With Quote
Old 08-13-2012, 10:11 PM   #7
des
des's Avatar
Cusco went in with a lot of wriggling.
des is offline   Reply With Quote
Old 08-13-2012, 10:30 PM   #8
dsgerbc
Drives: BRZ(sold), STI
So why front bar instead of rear?
dsgerbc is offline   Reply With Quote
Old 08-13-2012, 10:31 PM   #9
ABQautoxer
ABQautoxer's Avatar
The really simple answer is because its a street car and there is probably no street car that is really going to be faster in stock class with a rear bar, especially a RWD one. The front bar does two main things we want. 1. preserve camber by adding roll resistance to the front. 2. It assists with inside rear tire wheel spin. While the car has a torsen, it only works if there is load on both rear tires.
TomR
Old 08-13-2012, 10:38 PM   #10
xwd
My current setup:
SCCA CS
Current:
245/40/17 Hoosier A6s on 17x7 +42 Velox PG-5S
Subaru crash bolts
aFE oiled air filter
Perrin 2.5" catback without resonator and custom track pipe for larger events
Future:
Likely a front swaybar
Some shocks, still deciding what route to go
Old 08-13-2012, 11:13 PM   #11
dsgerbc
I know why people put huge FSBs on other Subarus, but I'm not too sure it is useful on a BRZ.
I'm not sure too much roll/weight transfer is an issue with this car on street tires. Is it?
On the other hand, a bit bigger RSB might help with turn-in.
I've only autox'ed it once, and on stock tires.
Old 08-13-2012, 11:22 PM   #12
dsgerbc
Hm, interesting wheel.
Old 08-13-2012, 11:25 PM   #13
ABQautoxer
ABQautoxer's Avatar
Only one way for sure but I'm going to bet yes, just a question of how big.
TomR
Old 08-14-2012, 08:22 AM   #14
Biggins
Drives: Yes
The BRZ/FRS is RWD. You want a bigger front bar and a small/OEM or no rear bar for most RWD cars with a stock(ish) set-up.
I run RTR but will likely switch to CS next season, so...
-Camber bolts
-17x7s with 225 Dunlops/Yokos/Hoosiers
-Bigger front anti-sway
-Konis (when available)
-Catback
Biggins is offline   Reply With Quote
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
In need of advice (full setup) computertech01 Electronics | Audio | NAV | Infotainment 8 08-02-2012 06:23 PM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 06:31 PM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
