#15 |
Not a fuckiddly chance I sound like him.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: | 15limited (06-29-2017), lantsalot (07-18-2017), soulreapersteve (06-29-2017), Ultramaroon (06-28-2017) |
#16 |
Drives: Subaru BRZ
| The Following User Says Thank You to JD001 For This Useful Post: | soulreapersteve (06-29-2017) |
#17 | |
........ there ....... you needed that ...... ![]() Now, go find out what's wrong with your car. * tire pressure ..?? * EPS got messed up (as mentioned) * alignment got messed up (as mentioned) * you're just recovering from a hangover (ask @Cole ) * Bubba replaced the battery .. ?? Seriously, what else have you recently done to the car, except change the battery...?? humfrz |
#18 | |
Drives: Grrrr
Do you really think the a change in your lead/acid accumulator that has affected your "handling" to this degree? Have you checked your tyre pressures? |
#19 |
Drives: car
I swapped it for a 26R-DL at autozone. It weighs about 28lbs.
I knew this thread would turn into a heckle show of who can and can't feel the weight difference in their car. I stick with the old equation of force = mass x acceleration. I pretty much immediately knew there was a difference as soon as I took it on my favorite back road, which has a left corner that normally makes the front end of my car bump up twice, I take the corner on the battery with 15lbs more weight and the front end doesn't respond in nearly the same lively way. Then I tried taking the right corner at my apartment, which normally allows my car to do a quarter turn easily, instead the front right sunk right into to it like a stone, did not feel good. Too tired now to go out an re-learn the throttle again and test this battery, but I'm satisfied that I've got a battery that weighs nearly the same as stock. |
| The Following User Says Thank You to radroach For This Useful Post: | Ultramaroon (06-28-2017) |
#20 | |
Drives: '13 10 Series FRS #1203
There are so many more variables that would make it feel different in the way you described. Have you ever corner balanced a car? I can tell you right now that 15lbs isn't enough to upset it so much that you would feel it in that way. Just drive your car and stop filling your own head with BS
#21 |
Drives: car
No, but i have heard some stuff about corner balancing here, someone mentioned in a different thread how adding an OEM Audio+ sub in the rear perfected the corner balance, a 30lb difference or so.
#22 |
Drives: 2005 Toyota Camry
If changing the battery destroys the handling in a car, then every time I fill up with gas the handling in my car (or any car) is completely destroyed!
| The Following 4 Users Say Thank You to mav1178 For This Useful Post: |
#23 | |
Drives: 2017 BRZ
It sounds like a broken part in the suspension, uneven tire pressure, a whacked out alignment... Depending on what it is, it could be dangerous, but it's not from a 20lb corner weight change. C |
#24 |
Because compromise ®
Drives: Red Herring
In for the group buy.
#25 | |
Drives: Grrrr
Yes, have a lie down. |
#26 | |
#27 |
I had Baconator combo for dinner in the car on the way home.
I was full lock right to keep the damn car going straight. |
| The Following 8 Users Say Thank You to jvincent For This Useful Post: | 15limited (06-29-2017), Brzerker (09-07-2017), Busybee (05-12-2020), Captain Snooze (06-28-2017), EastBayCanuck (06-30-2017), lantsalot (07-18-2017), Overdrive (06-29-2017), STV3 (06-29-2017), Tcoat (06-28-2017) |
#28 |
Drives: 13 mt fr-s
if its a "stone" in the corner. step on the gas more, and take your turn differently.
| Engine Won't Crank - Battery or Worse - Sanity Check | StrangeLove4791 | Issues | Warranty | Recalls / TSB | 16 | 02-22-2017 11:18 PM |
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 12:35 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
| Lowering Springs Making Handling Worse? | Jeff01234567 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 75 | 07-31-2014 02:21 PM |
| Aftermarket suspension making handling worse? | RaceR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 82 | 07-24-2014 10:39 AM |
