Old 07-25-2017, 05:50 PM   #15
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
There are 2.5" and 3" options with the kit.
Really, unless your going huge hp the 2.5" should be sufficient. So any OP/FP that fit stock would work.
GTHachiRoku is offline   Reply With Quote
Old 11-18-2017, 07:47 PM   #16
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
We just updated our site with more options and many more photos -
We do have a Black Friday Coupon for those who have asked.
Link Here
86SPEED is offline   Reply With Quote
Old 12-26-2017, 05:08 AM   #17
grichardt
grichardt's Avatar
Updated with some small YouTube videos.
*8 month review*
Kit is still awesome!
I am starting to want to change some things such as the BOV and upgrade to the garrett turbo.. Not really looking for more power but better throttle response.
I have developed a little oil leak at the exhaust housing on the turbo....Need to figure that out this week. Dynoed a couple months back at 320whp/271 ft.lbs
[ame="https://www.youtube.com/watch?v=1cvpIzv2Mc4"]Subaru BRZ jdl turbo v2 kit dyno run - YouTube[/ame]
Next up for changing is wheel/tire and aero....
grichardt is offline   Reply With Quote
Old 01-11-2018, 02:43 AM   #18
CHMBRZ
Drives: 2016 Subaru BRZ Limited
did you mount those little spacers for the intercooler underneath?
CHMBRZ is offline   Reply With Quote
Old 01-12-2018, 10:32 PM   #19
grichardt
grichardt's Avatar
I didn’t originally. I have since gone back and put them in.... definitely made the intercooler top bracket to long so I had to cut it down a bit
Old 02-06-2018, 01:32 PM   #20
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
Were you able to find that leak? Was curious to see where the oil leak was coming from as I’m waiting for my kit with a GT2860RS..
kimcheefists is offline   Reply With Quote
Old 02-06-2018, 02:58 PM   #21
armstrom
Drives: none
Oil leaks on ball bearing turbos are often due to too much oil pressure. The stock oil pressure is usually more than required for a ball bearing CHRA so a fitting with a smaller orifice is usually used to avoid oil getting through the seals. I'm not sure what JDL supply.
Further reading: https://www.turbobygarrett.com/turbo...oil_restrictor
-Matt
armstrom is offline   Reply With Quote
Old 02-08-2018, 05:45 AM   #22
grichardt
grichardt's Avatar
Coming from oil return line. Added hose clamps on it and it has gone away
Old 02-08-2018, 09:39 PM   #23
kimcheefists
Drives: 2017 BRZ PP
-Matt
@Jesse@JDLAutodesign Would you say that the Garrett BB turbos in your kits benefit from having a restrictor installed at the oil feed? I know our engines have 90+psi of oil pressure at cold start idle and according to the article armstrom provided, the turbo should be receiving 40-45 psi at maximum engine speed..just wanted your opinion on the subject.
Old 02-09-2018, 12:35 AM   #24
choiboie
Drives: 2013 Fr-S UltraMarine
Originally Posted by GTHachiRoku View Post
How are you liking the dump tube? I'm running one (with stock muffler) and it's glorious.
Same here. U can hear the turbo spooling better!!
choiboie is offline   Reply With Quote
Old 06-30-2018, 10:15 PM   #25
grichardt
grichardt's Avatar
Update: 1 full year done with this turbo kit... 11k miles. No issues with the kit minus a small oil week which was my fault. Tune from James at HRI is still great. Need to do spark plug soon but other than that the car performs flawlessly.
Old 07-03-2018, 01:43 PM   #26
mrloko
Drives: 2017 Subaru BRZ
Bro thank you so much for updating us,
People like me doing research on the kit and its reliability need to see these things!!
mrloko is offline   Reply With Quote
Old 07-22-2019, 09:05 PM   #27
grichardt
grichardt's Avatar
Update!!!!
Car has been running this kit for over 2 years. I have moved to south Texas where the heat has shown no mercy on the car. Car still running strong but clutch and tranny problems have shown up. Engine still good at 88k miles.
Old 01-04-2020, 12:34 PM   #28
irishslim69
Drives: 2017 GT86
First thing I'll say is, customer service is great.* Im sure they were tired of hearing from me as I can be quite impatient.* The kit build time up until it was delivered to my door was almost 1 month exactly.* Was a wonderful surprise when it arrived Christmas Eve.* Arrive in two packages and took two UPS guys to drop it off.* One box was damaged but because the kit was package extremely well, no damage to components occurred.
On to the install......no instructions which made this install extra fun.* All in all, it took me the better part of a week to complete.* Mainly because I only worked on it a couple hours a day.* Ease of install, I give it 6 out of 10.**
On to my gripes.* First off, the tubing for the coolant running from the throttle body to the turbo is slightly bigger than the fittings on the block and the throttle body.* So when tightening the clamps to ensure the hoses sealed, the hose clamps broke.* No biggie, I went out the the hardware store and purchased heavy duty clamps.**
Next, the flange where the turbo mounts to the header could be turned about 2 degrees toward the engine.* There is plenty of clearance between the turbo and the serpentine belt but there is only about 1/8in clearance between the turbo and the radiator fan shroud.* Tweaking the flange inward would also allow the oil supply and return lines to be more vertical.* I also believe this adjustment would help with the downpipe as well.* My downpipe is barely touching a connector on the front of my engine.* I ended up wrapping the downpipe on top of the existing thermal coating and installing a turbo blanket.**
Great kit.* I will continue the review after tuning.
Sent from my LM-V405 using Tapatalk
irishslim69 is offline   Reply With Quote
brz turbo, jdl auto design, jdl turbo install
Turbo install shop in the IE? drz400dude Southern California 0 04-26-2017 10:57 PM
SBD Turbo Install tofurun Forced Induction 10 02-12-2017 10:01 PM
AVO Turbo Kit Install Dammod AFRICA 110 09-10-2016 12:54 PM
BRZ Turbo install Saifalkhalifa1 Forced Induction 6 03-27-2016 10:11 AM
Turbo install!! SoCal80six FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 10-08-2015 12:16 PM
