Member's Car Journals Car journals by our members. |
06-25-2017, 02:46 AM | #1 |
Old Greg's 2013 WRB Boosted_BRZ
Hello, I figured after years of being on this page I would finally make a journal for the car. Yes, its not just a clever title. It is boosted. I recently made a DIY for the JDL v2 UEL turbo kit. So yeah, that is my car and here are the specs. 2013 Subaru BRZ Limited 6spd. 63k on Odometer Engine JDL v2 UEL Turbo manifold ceramic coated bronze JDL 2.5" downpipe ceramic coated bronze JDL Radiator Shroud w/ SPAL slimfans Precision 4831 Turbo (9.4lbs) Precision 39mm external wastegate (open dump) Turbosmart VeePort blow off valve Radium Dual catch cans 1320 dual resonated front pipe Zeta performance cat-back Ecutek tuned by HRI Tuning AEM UEGO Wideband AEM Boost Torque Solution Black Turbo Blanket MAPerformance Oil Cooler Driveline ACT clutch/flywheel Velox clutch fork and pivot ball Whiteline positive shift kit Torque Solutions rear shift bushing Torque Solutions rear diff bushings Suspension Skunk2 Pro-C Coilovers Skunk2 front sway bar endlinks Wheels/Tires 17x8 Enkei RPF1 +35mm offset GOLD 245/40r17 BFG G-force sport comp 2 A/S Aesthetics Anarchy motive Shift knob Grimmspeed tooltray pulley cover (modified to fit turbo set up) 86speed hood struts Block8head dual gauge pod. Diode Dynamics Reverse/tail as turn mod Velox Slanted hood vents w/rain guards Verus Carbon Sidemarker deletes Old Mods Removed Open Flash Tablet CNT UEL Header ST Hard Intake Inlet Eibach Pro Kit Springs I do quite a bit of backroad driving which I document on my YouTube channel. Here is a clip, check out my channel for more videos of backroads, autocross, drone footage and my annual road rally I host The Peppermint Road Rally. [ame="https://www.youtube.com/watch?v=G9ODCDvYIoo"]JDL TURBO KIT drive along BRZ Open Dump - YouTube[/ame] [ame="https://www.youtube.com/watch?v=0hiOR2pxTVA&t=345s"]Subaru BRZ Back road driving. SR66 Second Half - YouTube[/ame] [ame="https://www.youtube.com/watch?v=hFALonmrKww&t=215s"]Peppermint Road Rally 2016 Starting Location - YouTube[/ame] I'll add more soon, just wanted to get started for now.
06-25-2017, 09:57 AM | #2 |
Ohne Titel
Drives: 2017 BRZ PP ISM
You ever drunk Bailey's from a shoe?
06-25-2017, 12:29 PM | #3 |
Ever go to a club where people wee on each other?
06-25-2017, 07:26 PM | #4 |
Ohne Titel
Please don't kill me. I have so much to give...
08-07-2017, 03:31 AM | #5 |
09-02-2017, 03:06 PM | #6 |
Couple photos from this past weekend. These are from the peppermint road rally that I host every year.
12-26-2017, 05:10 AM | #7 |
Forgot to update this awhile back. Dynoed at 320 whp/271 ft.lbs at 10psi
93 octane [ame="https://www.youtube.com/watch?v=1cvpIzv2Mc4"]Subaru BRZ jdl turbo v2 kit dyno run - YouTube[/ame] [ame="https://www.youtube.com/watch?v=Ys6nGnEGSN4"]Subaru BRZ jdl turbo kit dyno run - YouTube[/ame]
01-25-2018, 07:43 AM | #8 |
Drives: frs
Any fitment issue with your wheel/tire set up?
01-28-2018, 03:49 AM | #9 |
No, but 17x8 isn’t aggressive at all. First nicely, just need stickier tires to hold the power down to the road.
The Following User Says Thank You to grichardt For This Useful Post: | Teseo (01-28-2018) |
01-31-2018, 08:57 AM | #10 |
Tacticool_BRZ
Drives: ZC6 - AW11
02-02-2018, 08:41 PM | #11 |
Nice! Cool to see someone else with photos of my car
02-09-2018, 05:57 PM | #12 |
Received skunk2 pro-c coil over kit today. Got them installed and ride height set. Install was straight forward without any hiccups. Took a couple hours for the actual install and then an addition 4 hours to get adjusted to my liking (because I kept changing my mind back and forth)
For anyone interested my height is: 25" front (ground to fender arches) 25.25" rear This should be good for daily and autocross duty! *Hopefully* Dropped done a bit more to final ride height as posted above.
Tags |
block8head, boosted brz, grimspeed, jdl auto design, wrb |
Similar Threads | ||||
BRZ imported from PA to get Opti-Coat from Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 04-14-2013 02:08 PM |
New Audi S6 gets 22PLE by Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 03-10-2013 06:32 PM |
New Car Opti-Coat BRZ by Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 01-27-2013 02:34 PM |
Greg Gellas Opti-Coats a FRS | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 17 | 01-20-2013 08:55 PM |
New Years Eve Opti-Coat by Greg Gellas | Greg Gellas | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 01-07-2013 04:05 PM |
