Old 03-25-2016, 08:22 AM   #1
Saifalkhalifa1
Drives: 2016 BRZ
BRZ Turbo install
Im just wondering wether my 2016 brz has an oil feed and return for a turbo, or do i have to somehow create them
Saifalkhalifa1 is offline   Reply With Quote
Old 03-25-2016, 09:55 AM   #2
Northwest86
Drives: Velocity Orange 86 GT
There's a few places to route them depending on your setup. Some use the FA20DIT scavenger pump, some use a electric scavenge pump and tap onto the cam plate. Some probably tap into the sump etc for the return. It depends on if its high or low mounted really. For the feed the top gallery plug is usually used on some kits. It's the one between the AC compressor and the throttle body.
Northwest86 is offline   Reply With Quote
Old 03-25-2016, 10:19 AM   #3
STV3
Señor Member
STV3's Avatar
STV3 is offline   Reply With Quote
Old 03-25-2016, 10:23 AM   #4
Saifalkhalifa1
Drives: 2016 BRZ
I still haven't purchased the turbo yet, i'm currently debating with myself wether to get a turbo or a supercharger. I would obviously prefer the turbo however I fear the difficulty of installation. If possible please recommend me a turbo manufacturer if you have any experience in that area. Im not looking for crazy gains but I would like to bump the 200 existing hp to 275-300hp.
Old 03-25-2016, 10:39 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It's an N/A car, no oil feed/return form factory. You need to bung a weld for turbo oil return in the oil pan. You can get the feed from a number of areas like on the top of the block there's a plug you can remove and put a fitting to get the oil from there.
Or get creative and do something like the AVO turbo for feed/return.
Old 03-25-2016, 10:50 AM   #6
Northwest86
It sounds as if you may be well served browsing the kit threads around and deciding from there. The best Turbo kit wouldn't be available for a fair while to the export market and I can't really recommend any of the others. Jackson Racing Superchargers are definitely a solid option. Installs are easy for all the kits really.
Old 03-27-2016, 10:11 AM   #7
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I relocated my next to my ac because the T fitting on the oil pressure sensor kept leaking. If you need part numbers and links for parts used in can provide.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
brz turbo installment
AVO Turbo Kit Install Dammod AFRICA 110 09-10-2016 12:54 PM
Turbo install!! SoCal80six FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 10-08-2015 12:16 PM
HELP! Car won't fire after Turbo Install RedFR-s Forced Induction 40 08-08-2015 04:21 PM
New Turbo Install = Car Fumes?? xuimod Forced Induction 49 04-28-2015 03:21 PM
BorgWarner EFR / JDL turbo install!!! Infamous Performance Forced Induction 89 01-21-2015 11:38 PM
