#15 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Will do they should be here early next week. Compared to the Kosei's and RPF1 I think these will be better looking for the street that I can live with. The other 2 I would only rock on the track.
#16 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
17x8 +45 with a 235/40/17. Ever so slightly less diameter than stock(offsets the acceleration lowering of wider tires by slightly improving the gearing), similar weight tires, and more overall grip. Only problem is more limited tire choices. There are lots of good and light 17x8's for every price range.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
#17 |
Drives: '13 FR-S
I had a set of team dynamics 17x7 that were really really light - I think about 16lbs each or so - they served me well for a couple of years before I went wider.
#18 | |
#19 | |
#20 | |
Mountain Runner
#21 | |
Drives: 2014 BRZ Limited A/T
Listed online are: 215/45ZR17 - 91Y or 215/45ZR17 - 95W or AS3+ with these specs ok? Not sure about the Ws and Ys! Size: 215/45ZR17 91W XL Last edited by leevanf; 06-02-2017 at 03:55 AM. |
#22 |
Drives: 2017 CWP STi
Hey, im not too familiar with tire sizes. My 17x8s were 225/45/17
#23 | |
Only users lose drugs.
Drives: All the time
https://www.tirerack.com/tires/tiret....jsp?techid=35 |
| The Following User Says Thank You to venturaII For This Useful Post: | yelsew (06-02-2017) |
#24 | |
Little Member
Drives: Bloo - The 13' BRZ
These W and Y are speed ratings, W rated tires are tested above 168 MPH, while Y rated are tested above 186. Either way, both are Z rated tires and will handle whatever the car can dish out. Edit. Ventura posted a good link as I was typing this, they explain it pretty well The Ventus 215/45R17 size should be a good match for a 7.5" wheel. If you look at the tread width of the tire, it is right at 7.4" which hits the nail on the head for a 7.5" wheel.
| The Following User Says Thank You to yelsew For This Useful Post: | venturaII (06-02-2017) |
#25 | |
Lol - I didn't feel like typing all that. There are other links on that page as well which explain sizing, etc. which would be good for OP to read through. |
#26 | |
#27 |
Little Member
Just for some more confirmation, I am running 245/40 on an 17x8, and they do not look pinched and the response is decent. (Although they are a little skinnier than most max performance summers)
#28 |
Drives: 2015 BRZ
| will this wheel and tire combo fit with stock suspension without rubbing? | Andreasbrz14 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 05-23-2017 04:25 PM |
| Most Close to stock fit tire on 17x8.25 | Norinradd | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 10-29-2016 01:20 PM |
| How close is too close?: Gap between tire & spring perch | kodyo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-20-2015 01:32 PM |
| Can you stagger this tire combo? | Brody602 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 03-13-2014 07:12 PM |
| Functional tire combo | tintumz22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 02-06-2013 12:12 PM |
