Old 06-01-2017, 09:56 PM   #15
steve99
Originally Posted by kizz View Post
Damn, 2 CEL. One was P050B, I disabled the cat warm up to reduce noise on my neighbors. I am able to disable that code, but P013A is not in the definitions. Is there an easy way to add that DTC to the definitions without losing the A/F#3 tables?
EDIT: I looked in the XML definition and found both entries for P013A, but it still doesn't show in Romraider. o.o
You can safely disable P050B code its only and emission check code.
P013A is going to be more difficult, you will need to find someone skilled at rom disassembly, likely on romraider forums.
Did you remove that right angle adapter that's going to make rear 02 see lean condition.
And maybe try a second hand oem rear sensor from auto wreckers, they will all be same from 2012 to 2016 auto or manual car
Old 06-01-2017, 10:01 PM   #16
kizz
****weed
kizz's Avatar
Drives: Crystal Black BRZ
Ahh shit, I can't get to a lift right now and have to drive 2 hrs on saturday. Was hoping to disable the code cause it kills cruise control.
Will have to deal with it and remove the spacer when I get back, or maybe this weekend if I can get under the car.
Thanks for the help.
kizz is offline   Reply With Quote
Code P013A! Please help jarrensandoval Software Tuning 4 04-11-2017 05:17 PM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Secondary o2 sensor needed in Portland ASAP! DarrenDriven Northwest 2 02-21-2016 08:04 PM
Secondary O2 sensor needed for Cruise control? DJCarbine Engine, Exhaust, Transmission 31 04-10-2015 08:49 PM
WTB: Longblock, Stock header and secondary Cat (downpipe) CSG Mike Want-To-Buy Requests 3 08-13-2013 03:52 PM
