Drives: Scion Fr-S
Code P013A! Please help
Recently this code came up and it reads "oxygen sensor slow response rich to lean bank 1 sensor 2."
Has anyone experienced this before? I got my car tuned recently at Church automotive and it was explained to me that it could be a bad o2 sensor or maybe an exhaust leak. Any ideas on how to fix this ? |
#2 | |
You would need to do further diagnostics via logging and look at the afr readings of the front and rear 02 sensors and compare, with commanded AFR. also look for high LTFT. If you have no devices to log ecu parameters then take it to a shop Or just take a punt on the rear 02 being faulty Code P013A indicates problem with rear 02 sensor, but it could be exhaust leak or cracked header, or a multitude of other issues |
#3 | |
Drives: Scion Fr-S
#4 | |
Drives: UK GT86
.: Stealth 86 :.
#5 | |
Hmmm, Assumed the tuner would have know that if it was rear 02 connected flex kit :-) If they fitted a flex kit using the rear 02 sensor as input then the tuner needs to disable the rear 02 associated DTC in tune and also disable the rear 02 afr corrections. I can understand the tuner overlooking a DTC disable but once you queried them on the CEL code/DTC they should have immediately tweaked to the problem if they fitted flex kit and/or tuned car with kit fitted Simply clearing the code with a code scanner wont fix problem, needs to be done in tune. Last edited by steve99; 04-11-2017 at 06:55 PM. |
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
| u0115 code? | ThisGuy919 | Issues | Warranty | Recalls / TSB | 1 | 11-11-2013 12:09 PM |
