Old 05-19-2017, 07:50 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by sly View Post
Anytime the coolant is drained out of the car, Subaru recommends adding their cooling system conditioner when refilling with antifreeze. They put it in there from the factory so unless you have changed your coolant, it should still be in there.
The factory service manual says nothing about using the conditioner to prevent head gasket leaks.
If this was a known issue they would list it as "required materials" instead of "recommended materials" in the Service Manual.
Old 05-19-2017, 08:25 PM   #16
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
You're right. It's not required but recommended. The service manual gives the part number for the coolant and the cooling system conditioner so obviously it can be used in a BRZ.
I guess if you want to leave it out, that's your choice. But it's only $6 or so, so why leave it out and take that chance?
sly is offline   Reply With Quote
Old 05-19-2017, 08:34 PM   #17
mav1178
mav1178's Avatar
Yes it's only $6, but I've never heard of a modern engine requiring a specific type of coolant conditioner to prevent a head gasket leak.
-alex
Old 05-19-2017, 08:43 PM   #18
mav1178
mav1178's Avatar
Here's some additional info on SOA635071.
Looks like it was intended for earlier engines with head gasket problems. I am very doubtful we would need it in a modern engine.
Look at the bottle design vs the normal Holts Radweld.
http://www.scoobyenthusiast.com/suba...ner-soa635071/
Old 05-19-2017, 08:52 PM   #19
neilr
Drives: 2018 Cayman, 2013 FR-S
Since we are focusing on tiny sample sets, I should point out that my friend's wife's 1999 Impreza RS 2.5 (original owner) has never had engine problems of any kind.
It was also regularly maintained.
What point do you think you're making?
neilr is offline   Reply With Quote
Old 05-19-2017, 09:04 PM   #20
mav1178
mav1178's Avatar
There's simply not enough high-mileage FRS/86/BRZ documented among enthusiast circles to say "this engine has a similar head gasket problem like older Subaru engines".
Maybe a few years down the road, there will be some "a-ha" moment when some flaw in the FA20 is discovered from a longevity perspective. But there simply isn't enough high mileage cars to say whether the head gasket will just blow up after 100k or not.
The side discussion about coolant conditioners is more about previous engine design flaws and preventive maintenance when you change coolant.
Nissan had a "flaw" on the KA24DE for many years, where the upper timing chain guide will rattle and break off. For years, Nissan told techs to replace the tensioner and guides as a fix, since it tends to rattle because the chain is losing tension as the oil pump ages.
Then about 10 years after the KA24DE was introduced, Nissan updated their TSB to simply tell technicians to remove the guide and not bother with replacing it.
So to answer your question: no there is no known head gasket issue on this engine. Your wife's car's issue is irrelevant and unrelated and should not influence your buying decision.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
86kahl (04-10-2018), Tcoat (05-19-2017)
Old 05-20-2017, 07:33 PM   #21
neilr
-alex
Thank you for the longer explanation. Your previous post was unclear to me. :-)
Old 04-08-2018, 06:11 PM   #22
protechcaraudio
Drives: 2014 Scion FRS
My 2017 did it at 6k. I was driving down the freeway and when I got off flames poured out from under the hood. The gasket leak caused the coolant reservoir to overflow with oil, the coolant overflow hole squirts the excess out below the engine and above the exhaust where it ignited. No engine mods and I did the break in period properly so I have no idea what could have caused it.
Sent from my VS988 using Tapatalk
protechcaraudio is offline   Reply With Quote
The Following User Says Thank You to protechcaraudio For This Useful Post:
gravitylover (01-07-2020)
Old 04-08-2018, 07:48 PM   #23
CoolHandMoss
Drives: 2013 FRS
Why does it look like you're fixing that yourself on a 6k engine? Problems with a warranty claim?
CoolHandMoss is offline   Reply With Quote
The Following 2 Users Say Thank You to CoolHandMoss For This Useful Post:
Qadthane (04-09-2018), tomm.brz (01-06-2020)
Old 01-06-2020, 02:32 PM   #24
sw20kosh
Drives: 2013 Black FR-S
HPDE Time Attack enthusiast chiming in here with what I have seen with tracked FA20s.
I have just blown my 2nd head gasket. Both gasket blew under boost. 8 psi and 12-13 psi respectively. Both engines had about 40-50 track days on them.
Two other track buddies blew the gaskets under boost at about the same # of track days.
One track buddy blew his gasket while NA (header + tune + e85) but his motor had 60+ track days on it.
All of these drivers were driving at a rate of ~20 track days per year.
First symptoms observed by all drivers was coolant overflow bottle was overflowing with coolant during hot laps. Combustion pressure pushing coolant out of the system. Black specs of gasket coating could be observed in coolant. At idle with radiator cap open bubbles could be seen periodically rising to the radiator cap neck.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
exE36M3 (02-06-2021), gravitylover (01-07-2020)
Old 01-07-2020, 08:35 PM   #25
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Here is a slightly larger sample size:
Mechanic here, I'm under all makes of cars pretty often. Before buying my '17 I paid attention when I was under a subaru. Since the F engines have been put in service, amongst all our fleet of customers, I've not seen a single one leaking oil from the head gaskets like the EJs did. That old guy with a 16000km XV? He just got a new transmission under warranty, but the engine is fine. That salesman with 215000km on his outback? He's on his 3rd exhaust manifold and we did the rear diff seals this fall, but the engine is dry as a bone.
Those are the two extremes, but everything in between is the same, it's not a problematic engine like the EJ25 was. It's not a perfect engine, it's <<<sensitive>>> to RTV abuse for example, but for me there's no fear that I'll wake up one morning with it pissing oil from the head gaskets like an EJ.
The Following User Says Thank You to RZNT4R For This Useful Post:
YamahaR86 (01-08-2020)
Old 01-17-2020, 12:11 PM   #26
bhmax
Drives: 13 BRZ, 17 Focus RS
Does anyone have recommendations for making head gaskets last longer? Is OEM or a particular aftermarket HG better? I blew a stock one and more than likely now a Cometic one.
bhmax is offline   Reply With Quote
Old 02-06-2021, 11:34 PM   #27
exE36M3
2013 BRZ... 23000 miles. Headgasket started spraying oil top of the motor under the intake manifold. Used about a quart of oil month. I could place a paper towel on the HG seam leaving my house and when I arrived at the office <5 miles later, SOAKED with oil. The oil would leak onto the headers and fill my cabin with smoke.
Car was under CPO "Gold" level warranty. The Subie dealer techs refused to confirm it was leaking, even after 3 visits and 3 weeks worth of stays.
No, I don't think all the FA motors leak, but for us when it does, it sucks.
I ended up selling the car back to the dealer I got it from.
exE36M3 is offline   Reply With Quote
Head gasket install Andreas83 Engine, Exhaust, Transmission 1 09-07-2016 10:09 PM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 02:08 PM
Head Gasket leak? Carlsson Issues | Warranty | Recalls / TSB 8 10-23-2015 01:49 AM
Blown head gasket?? texasbound972 Engine, Exhaust, Transmission 29 05-19-2015 12:09 PM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 10:45 PM
