Old 04-27-2017, 08:42 PM   #15
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That is post-MAF unmetered air. Bingo
From that pic I can't tell what it is.
Old 04-27-2017, 08:43 PM   #16
zackegle
Drives: 2013 brz limited
Originally Posted by guybo View Post
The garage basically did everything wrong. Instead of diagnosing the issue they started swapping parts. If they changed the O2 sensors, checked the MAF (if they even know how to) and (the worst of all) put in fuel injector cleaner , they have demonstarted that they do not know how to diagnose a problem and don't understand how to interpret a CEL.
If you go back to the same garage, they will find a reason that it's your fault. Go to a better garage.
so you remeber on the other thread i posted about the piece of plastic i found stuck in the throttle body its from that plastic container thing on the intake i just found a hole on....
zackegle is offline   Reply With Quote
Old 04-27-2017, 08:58 PM   #17
zackegle
Anyone know what this tube is?
Old 04-27-2017, 09:06 PM   #18
Imrac
Drives: 13 SWP BRZ Prem
Was that thing rubbing on a pulley?! Lol damn
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 04-27-2017, 09:16 PM   #19
nunonuna
nunonuna's Avatar
Glad you found the cause 🖒🖒🖒 That piece you are holding is resonator I believe. I also remember your other post saying about plastic piece stuck in TB. Im surprised that no one @ subaru dealer caught that. I think you can easily find used part to replace or simply upgrade it by replacing silicone inlet.
나의 SM-G935V 의 Tapatalk에서 보냄
nunonuna is offline   Reply With Quote
Old 04-27-2017, 10:01 PM   #20
zackegle
they told me they checked my intake system too... that dealer is bullshit man i swear and yea i just ordered a perrin inlet tube so that deletes alot of the resonators as for now i found a pvc tube end one of those rubber things and stuck it on it and now my car idles great and the fuel trims are where they should be on my oft
Old 04-28-2017, 04:35 AM   #21
guybo
Huge E85 fan!
guybo's Avatar
Thumbs up
Yes, I do. And I told you that I was more concerned with where that plastic piece came from and how it got there than the piece itself. I'm glad you found it and it hasn't damaged anything.
Old 10-15-2017, 03:12 PM   #22
-Willis-86touge
Drives: Stock
Just found the same damn thing with the same problems. Urge everyone to check this seems the intake rotates and then this piece rubs again the front damper! Now I'm just worried about the plastic I guess I've been burning it up in the cylinders hope that doesn't cause any damage!
-Willis-86touge is offline   Reply With Quote
Old 03-13-2022, 12:47 PM   #23
ajiron
Drives: 2015 BRZ
This is an old thread but I just found it. My car had exactly the same P0171 and the resonator is also worn by the pulley. How is this not a recall???? Now I need to find out if I can do without the resonator (if that is the right word for it).
ajiron is offline   Reply With Quote
Old 03-14-2022, 12:17 PM   #24
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Before I switched to an aftermarket intake tube, I removed the resonator and plugged the opening with a blank from Lowe's plumbing dept.
Chech Engine Light On P219A P119E P0171 tonytduc Issues | Warranty | Recalls / TSB 4 09-21-2022 04:09 PM
Throwing P0171 and P1170 codes B-R-Z Software Tuning 39 01-27-2018 09:56 PM
too lean issue? p117B p0171 engine codes zackegle Issues | Warranty | Recalls / TSB 1 03-21-2017 08:03 PM
Crazy high LTFT, lean codes, e85... nickw14 Software Tuning 18 06-23-2015 08:55 PM
P0171 and P1171 codes help! dejxx Issues | Warranty | Recalls / TSB 3 03-24-2015 11:36 AM
