| CANADA Canada |
#15 | |
Drives: '17 Camaro SS 1LE
![]() Judging by the question about negative camber, I assume these camber figures above are negative and not positive, right? |
#16 |
Drives: '13 BRZ
#17 |
#18 | |
Drives: '13 BRZ
Whiteline front camber bolts. Nothing in the rear. Sent from my iPhone using Tapatalk |
#19 |
Drives: 2013 frs whiteout
Front should be negative camber....camber bolts should help with this. Re install and Re align. Get the toe as close to zero in the front. No rear toe adjustment with a stock car
#20 |
Not a troll
#21 |
Yeah, do yourself a favor and get them to fix it to ~-1 to -1.5 camber in the front to make use of your camber bolts. Rear you can't do anything about without aftermarket camber adjustment.
#22 | |
Toe is definitely adjustable both front and rear with 100% stock parts. People buy aftermarket toe arms if they're drastically altering camber with a LCA because the stock adjuster doesn't have enough range if you've drastically changed the length of the LCA.
#23 |
Sorry to misinform the OP..my bad lol..but definitely should be negative with the use of camber bolts...did I get that right? Lol ..
#24 | |
#25 |
#26 |
Drives: 2016 Scion FRS
My steering wheel is a little off....can I just go to any place to get an alignment?
I don't need all this hardcore stuff for tracking etc since I just drive like a grampa in the Toronto traffic >_< |
#27 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
NV Auto can dial you in no problems. Just went there on Friday:
#28 |
Not a troll
| alignment shop ? | FR-Sky | Northern California | 17 | 04-08-2016 10:33 PM |
| Recommended Alignment Settings? | BFIFE22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-27-2015 04:57 PM |
| Alignment settings for Auto club speedway | ddeflyer | Tracking / Autocross / HPDE / Drifting | 12 | 07-08-2015 08:10 PM |
| Recommended Toe Alignment Settings | brillo | Tracking / Autocross / HPDE / Drifting | 18 | 02-05-2014 11:36 AM |
| RCE yellow springs. Expected alignment settings after install. | diss7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 02-24-2013 02:48 PM |
