Old 03-30-2017, 02:44 PM   #15
Schace
Drives: 2016 Scion FRS
I'm even showing 15 ohms at the the Trac buttons when I measured resistance
Sent from my Pixel XL using Tapatalk
Schace is offline   Reply With Quote
Old 01-01-2021, 08:56 AM   #16
thornad
Drives: 2016 GT86 N/A
Did you fix it ?
Hi, I have exactly the same issue as you did, with 15 Ohms at the ground pin when Igniton is ON, and 4 Ohms when Ignitiion is OFF.
Did you fix yours ? How ?
Thank You!
thornad is offline   Reply With Quote
Old 02-28-2025, 05:17 PM   #17
alfakarl
Drives: 2013 Scion FR-S & Subaru BRZ
I’m have my this same one issue. Where is the connector you are measuring voltage and ground? Got a pic?
alfakarl is offline   Reply With Quote
C1231 - Steering Angle Sensor STS-V Issues | Warranty | Recalls / TSB 6 01-13-2023 10:13 AM
Need cam angle sensor at autoclub asap D K Tracking / Autocross / HPDE / Drifting 0 05-07-2016 01:11 PM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 07:28 PM
The All New ATI FR-S/BRZ​/FT86 "Triple Meter" G​auge Pod ATIPods Interior Parts (Incl. Lighting) 7 09-18-2014 04:14 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
