#15 |
As other guys said it most likely a roblem with the VSC, this gets inputs from 4 wheel sensors and the steering angle input. if any of those are feeding in incorrect values or the steering is not reading zero at centre straight ahead position rearly weird stuff will happen.
if you have had a wheel allignment they can stuff it up if they alter teering zero position and dont reset it. you can use techstream to check thge steering sensor is showing zero at straight ahead and also check the readout from all four wheel sensors to see they read same value when going straight. |
#16 |
large difference in tyre pressures might also have an effect
#17 |
Drives: 2013 Scion Frs 6mt
Hmm I wonder what the hell that tech did... I'll check my tire pressure as it's been like 2 weeks.
#18 |
That's probably it
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#19 |
Here's a procedure but it's not specific for FR-s, there has to be a way to do it without a Techstream or going to a dealer
http://www.toyotanation.com/forum/88...libration.html
#20 |
Drives: 2016 Steel AT FRS
Does it only happen when you're driving alone, or also when you have a passenger? I've noticed I don't get enough weight transfer on left turns when I'm driving alone.
#21 | |
not playing cards
#22 |
the dealer told me it pulls to the left with the VSC because of "radial pull" from the tires...
Sounds like bs. Lol. Im going to head to another dealer and have them have it done, hopefully I'll have better luck. After the alignment the car does feel much better. Haven't checked my tire pressure yet and it's 12:41 am (EST). I'm so bored I may head up to wawa now hah |
#23 |
#24 | |
#25 | |
not playing cards
Oh, and -10 points for failure to check tire pressure. Get a gauge and toss that bitch in your glove box ...AFTER you use it!
#26 |
#27 |
In all seriousness, I assumed the dealer inflated my tires because they did end up rotating my them, lets hope they at-least got that right.
#28 |
not playing cards
Oh, fuck me.
| Humming noise on left turns. | kphan | Issues | Warranty | Recalls / TSB | 10 | 10-27-2016 11:49 AM |
| New front sway, a little unstable on left turns | loading_please_wait | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 07-20-2015 07:38 PM |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
| WTB: OEM Control Arms: Front Left & Back Left | norcalpb | Want-To-Buy Requests | 0 | 02-26-2015 08:55 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
