#15 |
It's not only the amount of psi, but how many cfm the turbo can push. 7psi on a gt28 is different than 7psi on a gt35.
#16 |
Drives: Late 2014 Subaru BRZ
My tuner didnt recommend going over 10psi with either 93 or flex fuel on a stock block. Our rods are paper thin and tuning for tomuch lowend torque may also bend the factory rods.
Needless to say, save for a block right away so you dont need to make that call to AAA.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#17 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
ran a mix of 93 and e85 for 19k miles on 10lbs with greddy t620z. Lots of daily and spirited drivings with 0 track days.
no issues at all. |
#18 | |
Junior
Drives: a car
2. 7 psi is relatively standard for boost on this engine, and alot of people have run 7-10 psi on pump or e85 and have done so for 10's of thousands of miles. Check build threads and owners threads for those kinds of anecdotes. 3. Pretty reliable. The one thing you should put emphasis on is the tune. The tune is the glue that will hold most of it together. Failsafes, boost cuts, ECBS, all those things can be incorperated into your tune assuming the proper hardware. Reliability also falls down to quality of parts. Dont expect an ebay turbo to last just as long as a properly taken care of garrett or borg warner.
| Safe amount of boost on stock engine? | Octane | Forced Induction | 51 | 12-06-2017 07:25 PM |
| GReddy T620z Turbo Kit -- save $1500 over retail! 350 WHP on e85 STOCK INTERNALS | ZeroTo86 | Engine, Exhaust, Bolt-Ons | 5 | 08-11-2016 09:36 PM |
| Fastest 1/4 mile on stock internals, 91-94 pumpgas, and street tires? | hmong337 | Tracking / Autocross / HPDE / Drifting | 1 | 07-14-2015 02:25 PM |
| Electronic Boost Controller Issues | 1BadFA20 | Forced Induction | 1 | 06-09-2014 01:21 AM |
| Scion Boost/Warranty Issues with Mods? | Marusich | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 10-17-2013 12:26 AM |
