| Engine Swaps Discussion of engine swaps. |
#15 |
Drives: 2015 Raven V8
Why do you need the frs/brz ecu? If you’re using a canbus module it should be sending it’s own signals. Your frs ecu is doing nothing. I didn’t bother to remove mine though. As someone else mentioned, wire go ecu standalone and just wire up canbus module for tach and power steering, etc.
#16 | |
Drives: 2013 Ultramarine FR-S
#17 |
I'm fairly confident the pin out is correct but I have nixed this idea and am going EMtron so that I can get everything 100% working properly the first go around.
#18 |
Drives: None
#19 | |
Drives: Supercharged GT86
The Motec takes care of all the CANBUS stuff but we still need to make a new engine loom to pin into the OEM connector in the engine bay |
#20 |
Yes the harness will be custom.
| 1JZGTE SWAP [QUESTIONS] | Edsc | Engine Swaps | 3 | 11-20-2016 08:33 PM |
| Questions on new swap idea, need input! | Tectoniic | Engine Swaps | 11 | 10-28-2016 05:20 PM |
| Questions Related to Hard-wiring Dashcam | carma143 | Electronics | Audio | NAV | Infotainment | 2 | 09-09-2015 05:26 AM |
| Stock amp/wiring questions | Matey | Electronics | Audio | NAV | Infotainment | 5 | 08-22-2015 08:28 AM |
| Engine swap questions | kaluce | Other Vehicles & General Automotive Discussions | 9 | 09-20-2014 05:48 PM |
