Old 04-03-2018, 09:56 AM   #15
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Why do you need the frs/brz ecu? If you’re using a canbus module it should be sending it’s own signals. Your frs ecu is doing nothing. I didn’t bother to remove mine though. As someone else mentioned, wire go ecu standalone and just wire up canbus module for tach and power steering, etc.
wutsaiu is offline   Reply With Quote
Old 04-03-2018, 10:06 AM   #16
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I think he is trying to attach the new engine harness to the body side of the factory engine harness plug and install the standalone ecu into the factory ecu plug via patch harness or the like. At least that is how it sounds to me.
Old 04-03-2018, 11:41 AM   #17
all4spl
I'm fairly confident the pin out is correct but I have nixed this idea and am going EMtron so that I can get everything 100% working properly the first go around.
all4spl is offline   Reply With Quote
The Following User Says Thank You to all4spl For This Useful Post:
DustinS (04-03-2018)
Old 04-03-2018, 11:52 AM   #18
Chris1083
Drives: None
Are you doing your harness?
Chris1083 is offline   Reply With Quote
Old 04-08-2018, 06:10 AM   #19
smudge
Drives: Supercharged GT86
Correct
The Motec takes care of all the CANBUS stuff but we still need to make a new engine loom to pin into the OEM connector in the engine bay
smudge is offline   Reply With Quote
Old 04-09-2018, 02:59 PM   #20
all4spl
Yes the harness will be custom.
1JZGTE SWAP [QUESTIONS] Edsc Engine Swaps 3 11-20-2016 08:33 PM
Questions on new swap idea, need input! Tectoniic Engine Swaps 11 10-28-2016 05:20 PM
Questions Related to Hard-wiring Dashcam carma143 Electronics | Audio | NAV | Infotainment 2 09-09-2015 05:26 AM
Stock amp/wiring questions Matey Electronics | Audio | NAV | Infotainment 5 08-22-2015 08:28 AM
Engine swap questions kaluce Other Vehicles & General Automotive Discussions 9 09-20-2014 05:48 PM
