Old 11-17-2016, 11:56 AM   #1
Edsc
Drives: Gt 86
1JZGTE SWAP [QUESTIONS]
Hi all,
First, our country having big tax on import cars so please if you intend to say something like get a manual or get another car.... just save it....
So my questions are
1) 1JZ VVTI Swap, what box we use ? R154 with ori GT86 rear differential and custom drive shaft ?
2) Wiring ECU, What function will be lost after 1jz swap ? such as ABS, Traction control etc. As I watch a video from youtube they claimed that their 2JZ swap still keep everything including traction control...
citated: EKanoo Racing 86
3) Is removing the transmission support for 1JZ transmission is reversable ?
Which mean I could weld the bracket back to the place and swap back the stock for everything ?
THank you
Edsc is offline   Reply With Quote
Old 11-17-2016, 12:20 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
You just need money and anything is possible
Old 11-17-2016, 12:51 PM   #3
86Boyz
Drives: on the highway to hell
86Boyz is offline   Reply With Quote
The Following User Says Thank You to 86Boyz For This Useful Post:
go_a_way1 (11-17-2016)
Old 11-20-2016, 08:33 PM   #4
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by Edsc View Post
Hi all,
So my questions are
THank you
I run Emtron KV8 for engine management, custom wiring harness. The only EMS that I'm aware of that keep the CAN system is Emtron, Motec, and Haltech. If money is no object, throw a Motec setup on there - Emtron also works but I'm the only JZ platform FRS chassis in the world so you'll have to take my word for it until I get the car back.
Your goals should dictate what transmission you end up with. I'm running a fully tap 6466 on my fully built 10:1 2JZ - an R154 wouldn't have worked for me.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Questions on new swap idea, need input! Tectoniic Engine Swaps 11 10-28-2016 05:20 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
LS3 Swap/body modification Related Questions S2K_Killer Engine Swaps 17 03-19-2015 06:21 AM
Engine swap questions kaluce Other Vehicles & General Automotive Discussions 9 09-20-2014 05:48 PM
Steering wheel swap questions firl21 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-02-2014 08:27 PM
