Old 11-26-2016, 06:41 PM   #15
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Originally Posted by nikitopo View Post
Are you tracking the car?
Currently autocrossing a lot (I'm the autocross chair for the biggest college sportscar club in the United States) but I'm going to start tracking next season. So let's go with yes?
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 11-27-2016, 12:49 AM   #16
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
I'm sure this is a dumb question but why are you looking for a camber plate for the stock struts?
I'm especially curious because I have the same setup as you - RCE Yellows on stock struts because I was too cheap to shell out $$$ for what I really wanted.
treminaor is offline   Reply With Quote
Old 11-27-2016, 04:12 AM   #17
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by Keenercarguy View Post
Wow those are so cheap, actually almost scary cheap lol... But do they 4x4 the stock front shocks because like 0.8* of camber isn't worth it to me if they 4X4 the front.
Their material is steel. That's why they are so cheap.
The only problem is their weight. But compared with stock ones it's not a big deal.
makinen is offline   Reply With Quote
Old 11-27-2016, 04:34 AM   #18
Keenercarguy
Mountain Runner
Originally I got the RCE Yellow's for the same reason, but I actually have the car dialed in perfectly on them now, all I really need is a bit more front camber. Since the car is already set up how I want it I don't feel that coilovers will be worth what they'd cost considering that I'm still on a budget: I'm already in the top ten percent overall where I autocross, battling with veterans driving supercharged and spec miatas on wide 200tw tries when I'm only on 225 Pilot SS with 340tw (at the moment). I know that if I can dial out just a tad more understeer then my car will shine on 200tw tires next season. I want to go for a FTD or two before I leave.
I guess I got lucky that the springs are exactly what I need for now, plus any non-rising camber plate I get now could in theory be used on coilovers later, or at least sold to cover most of the cost of another set.
Old 11-27-2016, 04:36 AM   #19
Keenercarguy
Mountain Runner
Ah I didn't notice that they weren't billet aluminum... Hm I honestly don't mind the weight as long as they have similar-or-better rigidity: I've already shaved a lot of weight off of the to front so I won't mind a pound or two.
Does anyone else have experience with the camber plates @Cole posted? I want some extra extra confirmation that they don't 4x4 the front haha
Old 11-27-2016, 04:23 PM   #20
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by VeloxEric View Post
Our top hats were designed directly around OEM CAD and do not alter ride height.
Eric, I wonder about the spherical joint. How long does that last compared to the stock bearing?
Would you consider/quote a custom design using ACBs?
Old 11-27-2016, 10:36 PM   #21
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
The spherical should last quite a long time, though it completely depends on use and environment. We use high-quality bearings in our suspension components. OEM unit will last longer but has significantly more compliance.
We cannot do custom components at this time, unfortunately.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 11-27-2016, 11:12 PM   #22
Ultramaroon
not playing cards
Oh of course! Barring a custom build, I guess I'll have to *cough* settle for your standard high-quality.
Old 11-28-2016, 12:50 AM   #23
makinen
makinen's Avatar
Drives: Toyota 86
RCE Tarmac springs + Koni Yellows + Silver project front camper plates
F -3deg camber, R -1.8deg camber
1/4" spacer+conical washer (F), 3/8" spacer (R) (as you know, conical washer is slightly thicker than stock.)
No 4x4.
Old 11-28-2016, 02:46 AM   #24
Keenercarguy
Mountain Runner
No 4x4.
Attachment 146518
HOLY CRAP that's a gorgeous set up. How does it handle under load!? And thanks for the added confirmation on the no-4x4 status!
Old 11-28-2016, 07:06 AM   #25
makinen
makinen's Avatar
Drives: Toyota 86
Better than front camber -2.3deg that was achieved by camber bolts only. With -2.3, slight understeer feeling. At that time, I had to wait until the car turns.
Old 11-28-2016, 08:58 AM   #26
churchx
churchx's Avatar
Drives: 2014 GT86
And even better that wheels are 16". Glad to see someone valuing function over form.
Old 11-28-2016, 02:11 PM   #27
sugoi
Drives: 2015 BRZ Limited CWP
Honestly, if you add camber plates, the change in ride height probably won't be noticeable.
sugoi is offline   Reply With Quote
Old 11-28-2016, 07:31 PM   #28
Cole
Not a troll
Cole's Avatar
Here's a picture of mine, just for some extra confirmation. Not the best picture, but you get the idea.
Camber plates with stock struts kbye Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-29-2016 01:37 AM
SOLD: Pre-assembled stock struts with RCE Yellows + Whiteline Com-C top mounts ATL BRZ Brakes, Suspension, Chassis 12 08-07-2014 09:23 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 04:45 PM
FS: RCE Yellows on stock struts (complete package) sw20kosh Brakes, Suspension, Chassis 6 07-02-2013 05:02 PM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 08:33 AM
