Old 02-03-2014, 12:53 PM   #15
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
What's Kosei? The pics look worse than Rotas.
fooddude is offline   Reply With Quote
Old 02-05-2014, 04:22 PM   #16
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
R.S-HawK is offline   Reply With Quote
Old 04-21-2014, 02:33 PM   #17
Kai81
Drives: White BRZ Limited
Originally Posted by Metallic BRZ View Post
Interested in quick opinions versus these two wheels. They are comparable in weight and the price is similar (therefore moot). What are your thoughts on durability? I've heard good things about Enkei but haven't heard much about Kosei (which doesn't mean anything since I don't know much about wheel companies). Thanks in advance.
Kosei 17 X 8
Weight - 15.8 lbs
Offset - 36mm
Construction - 1pc. Gravity Cast w/Flow Form Rim
RPF1 17 X 8
Weight - 15.6
Offset - 45mm
Construction - 1pc. Gravity Cast w/MAT Technology
Hey everyone,
I want to put the Kosei K4Rs on my White BRZ. I have Toyo T1 Sports in 225/45R17 and want to keep those tires. I can't decide if I should get 17X7 or 17x8. Tirerack shows the tires fit both sizes. I like the 7s are about a 1.5 lbs lighter, but I'm worried they will look too "sunk in" with a 50mm offset...Any thoughts?
Also, what do you think about the K1 TS?
Thanks
Kai81 is offline   Reply With Quote
Old 04-21-2014, 04:47 PM   #18
Skurj
Drives: SOLD...
I ran Kosei K1 TS on my yaris for a few years, nothing bad to say about them. Light weight, finish is very durable they worked great for me and cheap.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 04-22-2014, 07:55 AM   #19
evil_1998
evil_1998's Avatar
Drives: GT86
Originally Posted by Kai81 View Post
Hey everyone,
Thanks
@Kai81
Go 17x8 and use stock 215/45/17 they will fit fine. Then you can upgrade to 225/45/17 once they run out of tread. The good thing about 8" wide rim is you can upgrade to a wider tire if you want later.
The 17x7 +50 will be a tiny more sunken in than stock (17x7 +48), but shouldn't be a noticeable difference.
PROJECTGT86
evil_1998 is offline   Reply With Quote
Old 04-22-2014, 01:25 PM   #20
Kai81
Originally Posted by evil_1998 View Post
@Kai81
@evil_1998
Thanks for the help!
Old 04-22-2014, 05:50 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have both and haven't had issues with either.
Selling the K4R's soon though, simply because I don't have tires on those anymore.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-22-2014, 08:26 PM   #22
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
i got k4r and i think their great. look great and sit pretty nice and flush. just a bit of poke with 245 tires. only thing about them is you cant get them in a 9 inch wide.
http://www.ft86club.com/forums/showthread.php?t=9334
i've used them for autocross and daily with no issues.
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 04-26-2014, 10:37 AM   #23
Kai81
Ended up finding a set of 17x7.5 SSR Type-Cs on the cheap. Would have got the K4R otherwise.Name:  ImageUploadedByTapatalk1398523034.799057.jpg
Size:  258.5 KBName:  ImageUploadedByTapatalk1398523049.865589.jpg
The Following User Says Thank You to Kai81 For This Useful Post:
enjoyminutemaid (04-26-2014)
Old 04-26-2014, 01:08 PM   #24
Yoniyama
Drives: BRZ 2018
I have used them both on another Toyota, size 16x7.
The Kosei is slightly lighter.
My wife drove the Enkei over a pot-hole once and slightly bent one Enkei.
No mishap on the Kosie so far (although my wife didn't repeat the experiment with the Kosei).
The Kosei is more fussy with wheel mounting, needed to fit hub rings to make is hub-centric.
Yoniyama is offline   Reply With Quote
Old 04-27-2014, 08:46 PM   #25
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
The Enkei's are slightly lighter and look better IMO but only if you choose 17x9 concave face (which is only .1 pounds heavier than K4R's 17x8).
Wise is offline   Reply With Quote
Old 10-21-2014, 04:02 PM   #26
rtyp3
rtyp3's Avatar
Does Kosei offer the K4R in 17x9? Haven't been able to find mention of it.
Edit:: Nevermind, saw mention above that they don't come in 9".
rtyp3 is offline   Reply With Quote
Wheel Directory: Kosei K4R 17x8.0 +36 Vracer111 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 05-01-2017 11:39 AM
Enkei RPF1 17x8 Gold + Dunlop Star Specs 255/40/17 on SWP Premium Mitch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-08-2014 10:50 PM
OEM Stockers vs my new Hankook RS3's both 215/45/17 WoW! Blk RPF1 wheels MarkRacerX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 09:00 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 06:23 PM
Enkei Matte Black RP03 Racing Series wheels! toxicdrift Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-22-2012 03:37 PM
