| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
What's Kosei? The pics look worse than Rotas.
#16 |
Drives: '13 Gen Coupe 3.8 R
#17 | |
Drives: White BRZ Limited
I want to put the Kosei K4Rs on my White BRZ. I have Toyo T1 Sports in 225/45R17 and want to keep those tires. I can't decide if I should get 17X7 or 17x8. Tirerack shows the tires fit both sizes. I like the 7s are about a 1.5 lbs lighter, but I'm worried they will look too "sunk in" with a 50mm offset...Any thoughts? Also, what do you think about the K1 TS? Thanks Last edited by Kai81; 04-21-2014 at 02:47 PM. |
#18 |
Drives: SOLD...
I ran Kosei K1 TS on my yaris for a few years, nothing bad to say about them. Light weight, finish is very durable they worked great for me and cheap.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() Last edited by Skurj; 04-21-2014 at 04:58 PM. |
#19 | |
Drives: GT86
Go 17x8 and use stock 215/45/17 they will fit fine. Then you can upgrade to 225/45/17 once they run out of tread. The good thing about 8" wide rim is you can upgrade to a wider tire if you want later. The 17x7 +50 will be a tiny more sunken in than stock (17x7 +48), but shouldn't be a noticeable difference.
PROJECTGT86 |
#20 | |
Thanks for the help! |
#21 |
Site Moderator
Drives: Stuff
I have both and haven't had issues with either.
Selling the K4R's soon though, simply because I don't have tires on those anymore.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#22 |
Drives: Ultramarine Blue FR-S
i got k4r and i think their great. look great and sit pretty nice and flush. just a bit of poke with 245 tires. only thing about them is you cant get them in a 9 inch wide.
http://www.ft86club.com/forums/showthread.php?t=9334 i've used them for autocross and daily with no issues.
-- Kenny"I don't always use heel/toe, but when I do it's because racecar." |
#23 |
Ended up finding a set of 17x7.5 SSR Type-Cs on the cheap. Would have got the K4R otherwise.
| The Following User Says Thank You to Kai81 For This Useful Post: | enjoyminutemaid (04-26-2014) |
#24 |
Drives: BRZ 2018
I have used them both on another Toyota, size 16x7.
The Kosei is slightly lighter. My wife drove the Enkei over a pot-hole once and slightly bent one Enkei. No mishap on the Kosie so far (although my wife didn't repeat the experiment with the Kosei). The Kosei is more fussy with wheel mounting, needed to fit hub rings to make is hub-centric. |
#25 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
The Enkei's are slightly lighter and look better IMO but only if you choose 17x9 concave face (which is only .1 pounds heavier than K4R's 17x8).
#26 |
Does Kosei offer the K4R in 17x9? Haven't been able to find mention of it.
Edit:: Nevermind, saw mention above that they don't come in 9". Last edited by rtyp3; 10-21-2014 at 04:16 PM. |
| Wheel Directory: Kosei K4R 17x8.0 +36 | Vracer111 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 59 | 05-01-2017 11:39 AM |
| Enkei RPF1 17x8 Gold + Dunlop Star Specs 255/40/17 on SWP Premium | Mitch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 01-08-2014 10:50 PM |
| OEM Stockers vs my new Hankook RS3's both 215/45/17 WoW! Blk RPF1 wheels | MarkRacerX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 08-13-2012 09:00 PM |
| RPF1 are coming in 17x9 5x100 in Nov! | Cheddar | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 07-23-2012 06:23 PM |
| Enkei Matte Black RP03 Racing Series wheels! | toxicdrift | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 04-22-2012 03:37 PM |
