Old 08-11-2016, 11:31 AM   #15
Mishimoto
Drives: 2013 Subaru BRZ
Hello Everyone,
Thank you for all of the post.
If anyone is having any issue with any of our products, please contact us at Support@Mishimoto.com and one of our customer service reps will be happy to assist in resolving the issue.
You may also reach us via phone or live chat as well.
Best regards,
Mishimoto.
Mishimoto is offline   Reply With Quote
The Following User Says Thank You to Mishimoto For This Useful Post:
Strife26 (08-31-2018)
Old 06-20-2018, 12:36 AM   #16
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Long term feedback/update please.
Any problem/precaution when you wash the car or when it rains?
Originally Posted by Andrew360 View Post
Hey guys, I just installed the Trackspec T1 Hood Louvers. Although I haven't driven it much since I just installed it, I'd like to give my initial impressions and move on to a more in depth review later on.
A little background about my car. It's a turbo track car which I've spent quite a bit of time trying to make everything run correctly. Latest issue has been cooling. I'm using a Mishimoto oil cooler, thermostat (just keep it stock), and Mishimoto slim fans (don't get these either), and Koyorad radiator. Opted for the slim fans because the oem fan shroud was melting due to the turbo being so close and hot.
At the last event at Shenandoah, my p3 gauge showed coolant temps hit 245 before going into limp mode until the temps came down. Ambient air temperature was between 85-88 degrees. The amount of hot air trapped under the hood after coming off track was immense. The hood release latch was burning hot to the touch.
Now onto the actual review, I received the box in good condition. There was plenty of bubble wrap and packing material. They supply you with a template and all rivets and washers you'll need with detailed instructions. The installation was straightforward.
The quality of the vents are top notch. They sit nicely flush against the hood without any gaps in between. My coolant temps at highway speeds dropped between 10-20 degrees and temps come down much faster after idling and start moving again. It's also pretty cool to see the hot air come out of the vents including more choo choo noises from the engine bay. More testing will be done soon and updated accordingly.
Highway temps
Before: 200-220
After:190
andrewFT86 is offline   Reply With Quote
Old 06-21-2018, 03:21 PM   #17
Nope.
I take my car to a place with a power washer and you feed it coins for time...
andrewFT86 (06-21-2018), Strife26 (08-31-2018)
Old 08-08-2019, 10:52 PM   #18
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bumping this helpful thread for newer members...
Old 08-10-2019, 01:11 PM   #19
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I really want these, but I've never been comfortable cutting up my only hood. Have they ever been tested against the typical CF vented hood options e.g. Seibon?
As I mentioned in another thread, I need to find me a spare CWP hood!
mistople is offline   Reply With Quote
Old 08-10-2019, 04:06 PM   #20
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
or just cut yours and get it done with. if you want to revert back then buy a new hood. I for the longest time had this same fear and ended up always having two bumpers and two sets of tires and two hoods. eventually you just dont have the time or space for it.
theres another brand (wont name here since CSG is sorta the host) that doesnt cut the integral support and is somewhat /more/ reversible.
measure twice, cut slowly and always take off less than you think to check. You can always remove material, you cant reapply it easily.
and for siebon, I wont comment on the actual proven effectiveness of the vents
But there are multiple threads about the T1 trackspec and *insert other brand* hood louvers and their effectiveness (check out my car )
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
mistople (08-11-2019)
Old 08-12-2019, 02:14 PM   #21
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Yes. A/B testing was done for data on a few hoods on the same car.
CounterSpace Garage is offline   Reply With Quote
Old 09-20-2019, 12:53 AM   #22
jflogerzi
jflogerzi's Avatar
So it's not an issue driving the car in the rain...?
2013 Series 10 FRS #553
Old 09-20-2019, 02:35 PM   #23
ka-titties
Drives: 2013 BRZ Limited 6MT
Wait so you get more choo-choo sounds with these vents?
I'm sold.
ka-titties is offline   Reply With Quote
Old 09-20-2019, 03:48 PM   #24
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
This is neat!
iLuveKetchup is offline   Reply With Quote
TrackSpec Hood Louvers CounterSpace Garage Tracking / Autocross / HPDE / Drifting 55 12-29-2017 09:21 AM
TrackSpec Hood Louvers CounterSpace Garage Forced Induction 75 02-21-2017 08:09 PM
TrackSpec Hood Louvers CounterSpace Garage Cosmetic Modification (Interior/Exterior/Lighting) 15 07-27-2016 06:41 AM
